A 10-Gigabit transceiver in SFP+ form-factor that supports the 10-Gigabit LR standard, providing 10-Gigabit connectivity up to 10 km on single-mode fiber.
- HPE - SFP+ transceiver module - 10 GigE
- SFP+ transceiver module - LC/UPC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10 GigE
- Max Transfer Distance
- 10 km
- 1.4 cm x 5.6 cm x 1.2 cm
- 20 g
- Designed For
- Aruba 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl; HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10 GigE
- 10 Gbps
- 1310 nm
- 10 km
- IEEE 802.3ae
- 1 x Ethernet 10GBase-LR - LC/UPC single-mode x 2
- Compatible Slots
- 1 x SFP+
- 1.4 cm
- 5.6 cm
- 1.2 cm
- 20 g
- 0 °C
- 70 °C
- Designed For
- Aruba 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl , HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl
C2G 2m ST-ST 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua | In Stock | £9.55 |
C2G 2m SC-SC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua | In Stock | £10.78 |
C2G 2m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua | In Stock | £13.98 |
C2G 5m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua | In Stock | £17.78 |
