Your basket is empty
HPE HP V1410-8 8-Port L3 Unmanaged Switch
Quicklinx: 8BHWWS00 Mfr#: J9661A
The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
HPE OfficeConnect 1410 8 - switch - 8 ports - unmanaged
Switch - 8 ports - L3 - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
Switching capacity: 1.6 Gbps
MAC Address Table Size
1040 entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Jumbo Frames support
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50/60 Hz) 300 mA (operating)
15.6 cm x 9.5 cm x 2.5 cm
340 g
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
1040 entries
Jumbo Frame Support
9216 bytes
Status Indicators
Port transmission speed, port duplex mode, status, link/activity
8 x 100Base-TX RJ-45
External power adapter
Electric Current Required
300 mA (operating)
3.6 Watt
FCC Class A certified, CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, FCC Part 15 B, UL 60950-1, IEC 60950-1, EN 60950-1
15.6 cm
9.5 cm
2.5 cm
340 g
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
8BHW C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
8BHW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
8BHW C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
8BHW C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
