The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
Ease of Use
The HPE OfficeConnect 1410 Switch Series offers unmanaged plug-and-play simplicity.Comprehensive LED display with per-port indicators provides an at-a-glance view of status, activity, speed, and full-duplex operation.Auto-speed negotiation automatically selects individual port speed depending on client capabilities without the need for manual intervention.Flow control helps provide reliable communications during full-duplex operation. -
Connectivity and Performance
The HPE OfficeConnect 1410 Switch series provides automatic cable type detection for MDI/MDIX.These switches support Jumbo or Mini-Jumbo packets (based on model) for performance improvement of large data transfers.They double the throughput of every port with Half/Full duplex auto-negotiating capabilities. -
The HPE OfficeConnect 1410 Switch Series allows real-time traffic prioritization by supporting Differentiated Services Code Point (DSCP).IEEE 802.1p prioritization delivers data to devices based on the priority and type of traffic.They support energy-efficient Ethernet and allows lower power consumption when operated with IEEE-compliant client devices.
- HPE OfficeConnect 1410 16 - switch - 16 ports - unmanaged
- Switch - 16 ports - L3 - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- Performance
- Switching capacity: 3.2 Gbps
- MAC Address Table Size
- 8K entries
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Quality of Service (QoS), fanless, Mini Jumbo Frame support
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz) 300 mA (operating)
- 20.9 cm x 10.7 cm x 4.4 cm
- 0.65 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- Performance
- 8K entries
- Flash Memory
- 512 KB
- Status Indicators
- Port transmission speed, port duplex mode, status, link/activity
- 16 x 100Base-TX RJ-45
- Power Device
- External power adapter
- Voltage Required
- Electric Current Required
- 300 mA (operating)
- 3.6 Watt
- Rack Mounting Kit
- Included
- FCC Class A certified, CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, FCC Part 15 B, UL 60950-1, IEC 60950-1, EN 60950-1
- 20.9 cm
- 10.7 cm
- 4.4 cm
- 0.65 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day
- 0 °C
- 40 °C
- 15 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 15 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
