Your basket is empty
HPE HP V Conn FlexFabric 10Gb/24port Module for cClass Blade System
Quicklinx: 7VH5WS00 Mfr#: 571956-B21
Accessory Type: Blade Enclosure
Hurry, only 2 left in stock!
£15,289.72 ex VAT
£18,347.66 inc VAT
HP Virtual Connect FlexFabric 10Gb/24-port Modules are the simplest, most converged and flexible way to connect virtualized server blades to any data or storage network. VC FlexFabric modules eliminate up to 95% of network sprawl at the server edge with one device that converges traffic inside enclosures and directly connects to LANs and SANs. Using Flex-10 technology with Fibre Channel over Ethernet and Accelerated iSCSI, these modules converge traffic over high speed 10 Gb connections to servers with HP FlexFabric Adapters. Each module provides four adjustable connections (three data and one storage or all data) to each 10 Gb server port. Avoid the confusion of traditional and other converged network solutions by eliminating the need for multiple Ethernet and Fibre Channel switches, extension modules, cables and software licenses. Also, Virtual Connect wire-once connection management is built-in, enabling server adds, moves, and replacement in minutes instead of days.
HPE Virtual Connect FlexFabric 10Gb/24-Port Module - switch - 24 ports - plug-in module
Switch - 24 ports
Enclosure Type
Plug-in module
Subtype
10 Gigabit Ethernet
Ports
16 x 10Gb Ethernet (backplane) + 4 x 10Gb Ethernet/8Gb Fibre Channel SFP+ + 4 x 10Gb Ethernet SFP+
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 1, SNMP 2, HTTP, HTTPS, CLI
Auto-negotiation, LDAP support, VLAN support, wake on LAN (WOL), IGMP snooping, manageable
IEEE 802.2, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3aq
26.8 cm x 19.3 cm x 2.8 cm
1.27 kg
BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; Integrity BL860c i4; ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL460c G6, BL465c G6, BL490c G6, BL495c G6, BL685c G6
Switch - 24 ports
Enclosure Type
Plug-in module
Subtype
10 Gigabit Ethernet
Ports
8K entries
Fibre Channel
FC-AL, FC-AL-2, FC-FG, FC-FLA, FC-GS, FC-GS-2, FC-GS-3, FC-PH, FC-PH-2, FC-PH-3, FC-VI
Routing Protocol
IGMPv2, IGMP
Encryption Algorithm
SSL
Status Indicators
Port status, link activity, link OK, module locator
16 x 10Gbit LAN , 4 x 8Gb Fibre Channel - SFP+ , 4 x 10Gbit LAN - SFP+
UL, TUV, CISPR 22 Class A, cUL, VCCI Class A ITE, EN55022 Class A, CB, AS/NZ 3548 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, MIC Class A, CSA C22.2 No. 60950-1
26.8 cm
19.3 cm
2.8 cm
1.27 kg
10 °C
35 °C
10 - 90%
HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE Integrity BL860c i4 , HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL460c G6, BL465c G6, BL490c G6, BL495c G6, BL685c G6
Resources
The following resources are available for the HPE HP V Conn FlexFabric 10Gb/24port Module for cClass Blade System
Brand: HPE
Price Range Ex VAT: 1500+
