Smart AC power adapter (45 watt) - Non-power factor correcting (NPFC), with 7.4mm barrel connector, RC - Requires separate 3-wire AC power cord with C5 connector
- HP Smart non-PFC - power adapter - 45 Watt
- Power adapter - external
- Power Capacity
- 45 Watt
- Output connectors
- 1 x power DC jack 7.4 mm
- Designed For
- HP 11, 14, 15, 240 G6; Chromebook 11, 14; EliteBook 1030 G1, 1040 G3; Envy 15; ENVY x360; Pavilion 14, 15, 17; Pavilion TouchSmart 15; Pavilion x360; ProBook 11 G2, 430 G4, 440 G4, 640 G3, 64X G2, 650 G3, 65X G2; Spectre Pro x360 G2; Spectre x360; Stream 11, 13; Stream Pro 11 G3; Stream x360; x360
- Power Output Connectors Details
- Power Capacity
- 45 Watt
- Designed For
- HP 14-ac000nf, 14-ac005tu, 14-ac107na, 14-ac188ng, 15-ac011ns, 15-ac013nf, 15-ac013ns, 15-ac014ns, 15-ac016ns, 15-ac110nf, 15-ac119nf, 15-ac124no, 15-ac131nf, 15-ac132no, 15-ac142nf, 15-ac157nb, 15-ac157nf, 15-ac175nf, 15-ac198nf, 15-ac638tu, 15-ac658tx, 15-ac659tx, 15-ac660tu, 15-ac674tu, 15-af028cl, 15-af091ng, 15-af101ns, 15-af142nb, 15-g001sm, 15-g212au, 15-g317cl, 15-r018dx, 15-r085tu, 15-r224no, 240 G6 , HP Chromebook 11-v012nr, 14-ak001nf, 14-ak001tu, 14-ak002tu, 14-ak003tu, 14-ak004no, 14-ak004tu , HP Envy 15-ae000ns, 15-ae006tx, 15-ae031tx, 15-ae032tx, 15-ae100ns, 15-ae101nf, 15-ae101no, 15-ae102no, 15-ae103tx, 15-ae104nf, 15-ae108tx, 15-ae111nf, 15-ae144tx, 15-ae145tx, 15-as003nf, 15-as015tu, 15-as021tu, 15-as048tu, 15-as068nr, 15-as100nf, 15-as100nl, 15-as100nw, 15-as101nc, 15-as101nl, 15-as102na, 15-as102nc, 15-as102ni, 15-as103nc, 15-as103nf, 15-as104nc, 15-as111nl, 15-as112nf, 15-as113nf, 15-as114nf, 15-as115nf, 15-as120nr, 15-as120TU, 15-as121tu, 15-as123tu, 15-as124tu, 15-as125tu, 15-as126tu, 15-AS127tu, 15-as128tu, 15-as129tu, 15-as166nr, 15-bp001no, 15-bq100nl, 15-k050no , HP Pavilion 15-ab023ax, 15-ab027cl, 15-ab063cl, 15-ab083tx, 15-ab088ca, 15-ab101ax, 15-ab102au, 15-ab103au, 15-ab104au, 15-ab105au, 15-ab115ax, 15-ab115ns, 15-ab116ax, 15-ab116ns, 15-ab117ax, 15-ab117ns, 15-ab118ax, 15-ab119ax, 15-ab120ax, 15-ab121ax, 15-ab122ax, 15-ab123ax, 15-ab124ax, 15-ab126la, 15-ab127nc, 15-ab153no, 15-ab155nw, 15-ab215no, 15-ab216no, 15-ab217cy, 15-ab217no, 15-ab219cy, 15-ab220cy, 15-ab238tu, 15-ab245nf, 15-ab255tx, 15-ab256tx, 15-ab257tx, 15-ab261tx, 15-ab262tx, 15-ab294nb, 15-ab566tx, 15-n206ax, 15-p010ax, 15-p016ax, 15-p050no, 15-p095no, 15-p233cl, 15-p240na, 17-g030ds, 17-g077cl, 17-g102ni, 17-g117nf, 17-g119nf, 17-g120nr, 17-g121wm, 17-g130cy, 17-g153nh, 17-g160nb, 17-g161nf, 17-g180nf , HP Pavilion x360 11-k084no, 11-k100nt, 11-k112nw, 11-n130no, 13-s103la, 13-s185no , HP Stream 13-c114n, 13-c114nr
