The HP Smart Array P222 Controller is a low profile, 6 Gb/s, PCIe 3.0, Serial Attached SCSI (SAS) RAID controller that provides entry-level, storage performance, scalability, and data protection for select HP ProLiant Gen8 rack and tower servers. It features four internal and four external SAS lanes and delivers increased server uptime by providing advanced storage functionality, including online RAID level migration with flash back write cache, global online spare, and pre-failure warning. Data Compatibility among all models of Smart Array controllers allows simple and easy migration at any time when needs for higher performance, capacity, and availability increase. Even new generations of Smart Array controllers can understand the data format of previous generations of Smart Array controllers.
Increased Performance, Scalability and Data Protection, with Reduced Initial Setup Time
Up to 3x performance improvement over past generation, using DDR3-1333 cache memory.Greater scalability for explosive growth with up to 4 internal and 100 external drives.Long term data retention with 512 MB flash back write cache (FBWC) offered as a standard feature.Support for RAID 0, 1, 10, 5, 50, and RAID 6 and 60.New predictive spare activation for improved rebuild and maximized uptime.
- HPE Smart Array P222/512 with FBWC - storage controller (RAID) - SATA 6Gb/s / SAS 6Gb/s - PCIe 3.0 x8
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe 3.0 x8
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Buffer Size
- 512 MB
- Supported Devices
- Hard drive, disk array (RAID)
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- System Requirements
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 3-year warranty
- Designed For
- LTO-5 Ultrium; ProLiant DL160 Gen8, DL320e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, MicroServer Gen8, ML310e Gen8, ML350e Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8; StorageWorks SAS Rack-Mount Kit; StoreEver 6250, LTO-6
- Host Bus
- PCIe 3.0 x8
Storage Controller
- Interface
- 6 Gbit/s
- Buffer Size
- 512 MB
- Supported Devices
- Channel Qty
- 8
- RAID Level
- 1 x SATA 6Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane (internal) , 1 x SATA 6Gb/s / SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) (external)
- Compatible Slots
- 1 x PCI Express 3.0 x8
- Included Accessories
- Full-height bracket
- WEEE
- OS Required
- Limited warranty - parts - 3 years
- Designed For
- HPE LTO-5 Ultrium 3000 , HPE ProLiant DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL380e Gen8, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, SL210t Gen8 1U Node, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray , HPE StorageWorks SAS Rack-Mount Kit , HPE StoreEver 6250, LTO-6 Ultrium 6650
