Your basket is empty
HPE HP S/Works D2700 Disk Encl.SFF
Quicklinx: 71GBWS00 Mfr#: AJ941A
Type: Storage enclosure
Controller Type: None
Hurry, only 1 left in stock!
£1,419.78 ex VAT
£1,703.73 inc VAT
Has your business exceeded your storage capacity? Manage your small and midrange business' growing storage needs by deploying the HP D2000 Disk Enclosures, the next generation 6 Gb SAS low-cost, high-capacity, tiered external storage system. The HP D2000 Disk Enclosures are ideal for your small application environments, remote offices and departmental locations. The new 6 Gb SAS enclosures-Large Form Factor (LFF) D2600 with 12 drive bays and Small Form Factor (SFF) D2700 with 25 drive bays-offer flexible, modular solutions to simplify capacity expansion of HP ProLiant and Integrity server environments and MSA Arrays (SFF only) to external storage without having to make the full move to SAN or NAS. This allows you to buy what is needed today and purchase additional capacity as data storage needs grow. Total support can grow up to 96 LFF or 200 SFF drives as needed.
HPE StorageWorks Disk Enclosure D2700 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
15 TB
0 (installed) / 25 (max)
Supported Drives
SATA-300 / SAS-2
Hard Drive
0 HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
45 cm x 56.7 cm x 8.8 cm
17.2 kg
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
25
Supported Drives
SATA-300 / SAS-2
Storage
15 TB
Hard Drive
HDD - hot-swap
0
Expansion Bays
25 (total) / 25 (free) x hot-swap - 2.5" SFF
1 x SAS 6Gb/s
2 x SAS cable - 50 cm
Rack Mounting Kit
Included
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
300 Watt
45 cm
56.7 cm
8.8 cm
17.2 kg
10 °C
35 °C
10 - 90%
Brand: HPE
Price Range Ex VAT: 1000 - 1500
