Your basket is empty
HPE HP RDX Removable Disk Backup System
Quicklinx: BLDVWS00 Mfr#: C8S07B
Type: Disk drive
11 in stock
£115.25 ex VAT
£138.30 inc VAT
HPE RDX Removable Disk Backup System is a rugged, removable, easy-to-use, cost effective, disk backup solution for servers and workstations. It is the ideal backup solution for remote locations or small to medium businesses with little or no IT resources that are in less than ideal locations such as a busy office, field base sites, or business that require mobility. The new HPE RDX+ is perfect for these environments due to its ruggedness and the fact that it only requires a USB connection, no separate power source/cord required. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station. The HPE RDX Removable Disk Backup System offers fast disk-based performance with the ability to store 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360 GB/hr.
HPE RDX Removable Disk Backup System - RDX drive - SuperSpeed USB 3.0
RDX drive - external
SuperSpeed USB 3.0
10.98 cm x 17.75 cm x 5.18 cm
540 g
Storage Removable
RDX
Media Type
RDX
Data Transfer Rate
600 MBps (external) / 100 MBps (internal)
SuperSpeed USB 3.0
10.98 cm
17.75 cm
5.18 cm
540 g
Storage Removable
RDX
Media Type
RDX
Data Transfer Rate
Average Seek / Access Time
12 ms
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable
MTBF
550,000 hours
VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, UL 60950, CISPR 22, FCC
6.6 Watt
Software Included
Drivers & Utilities, HP RDX Continuous Data Protection Software
Linux, Microsoft Windows
5 °C
45 °C
20 - 80% (non-condensing)
Type: Disk drive
Brand: HPE
Price Range Ex VAT: 100 - 150
