HPE RDX Removable Disk Backup System is a rugged, removable, easy-to-use, cost effective, disk backup solution for servers and workstations. It is the ideal backup solution for remote locations or small to medium businesses with little or no IT resources that are in less than ideal locations such as a busy office, field base sites, or business that require mobility. The new HPE RDX+ is perfect for these environments due to its ruggedness and the fact that it only requires a USB connection, no separate power source/cord required. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station. The HPE RDX Removable Disk Backup System offers fast disk-based performance with the ability to store 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360 GB/hr.
Backup and Recovery Made Easy
The HPE RDX Removable Disk Backup System delivers a rugged, portable cartridge design protecting hard drive information and making transporting data between locations easy and more recoverable. Add a disaster recovery strategy to your business by simply rotating cartridges off site. off-site.Complement your cloud storage and implement best practices with a local backup copy that allows you faster access to critical data whenever you need it. Protecting your information both on- and off-premises.Delivering hard drive data transfer speeds and built in anti-vibration buffers, to increase read/write speeds, lowering the time it takes for incremental or full backups. This leaves you free to concentrate on running your business.As backup needs grow, you can easily and affordably expand your system by simply adding more cartridges - no new is hardware required. The HPE RDX Removable Disk Backup System supports disk spanning so data can bridge multiple cartridges.Compatibility across various operating systems and virtualization platforms makes it simple to adapt into any small business environment. You can also use Fixed Disk mode for automated backups via the native Microsoft Windows operating system. -
Unmatched Portability
Low-power ruggedized design offers flexibility to plug it in anywhere and feel confident the data is always available and safe.Cartridge style hard drive has a 97 percent survival rate compared to 0 percent for ordinary USB drives in a independent drop test.Built in static protection eliminates server or workstation failures due to statically charged peripherals. -
Fast Backup and Recovery
Ability to recover quickly with disk to disk backup performance reaching speeds of up to 360 GB/hr.Supports drag and drop file access making backup as simple and convenient as the click of the mouse.No need to worry about backups being larger than disk space, with disk spanning just add cartridges during the backup process, dynamically increasing the backup.Inner buffers built into the system lower disk drive vibration, increasing read/write disk performance. -
Easy Integration
HPE qualified and tested, making it easy to integrate into your server storage and networking environments.With fixed disk mode capability, RDX easily integrates into multiple small business operating system environments.Internal dock option makes it easy to configure with ProLiant and StoreEver products.
- HPE RDX Removable Disk Backup System - RDX drive - SuperSpeed USB 3.0 - external - with 2 TB Cartridge
- RDX drive - external
- Interface
- 10.98 cm x 17.75 cm x 5.18 cm
- 540 g
- Storage Removable
- RDX cartridge
- Media Type
- RDX cartridge
- Data Transfer Rate
- 600 MBps (external) / 100 MBps (internal)
- Power
- AC 120/230 V (50/60 Hz)
- Bundled with
- 2 TB Cartridge
- Designed For
- ProLiant MicroServer Gen10 Entry
- Interface
- 10.98 cm
- 17.75 cm
- 5.18 cm
- 540 g
- Bundled with
- 2 TB Cartridge
Storage Removable
- RDX cartridge
- Media Type
- RDX cartridge
- Average Seek / Access Time
- 12 ms
- 1 x USB 3.0 - 9 pin USB Type B
- Media Included Qty
- 1
- Cables Included
- 1 x USB cable
- MTBF
- 550,000 hours
- VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, UL 60950, CISPR 22, FCC
- Voltage Required
- 6.6 Watt
- Software Included
- Drivers & Utilities, HP RDX Continuous Data Protection Software
- OS Required
- Linux, Microsoft Windows
- 5 °C
- 45 °C
- 20 - 80% (non-condensing)
- Designed For
- HPE ProLiant MicroServer Gen10 Entry
