How are you planning to deploy and manage multiple servers at your company's growing number of branch offices? The HP ProLiant ML350p Gen8 Server series is the latest generation of the best-selling ProLiant ML 2P servers delivering best-in-class performance, availability, maximum expandability and simplified management for remote branch offices of large enterprises, growing businesses and data centers.
Improved Capacity and Performance on Compute and Storage
Intel Xeon processor E5-2600 v2 product family offers increased performance, improved security and efficiency for demanding workloads.The HPE Smart Storage Administrator management and configuration application provides a single pane of glass for HPE Smart Storage products and solutions.HPE Smart Array Controllers maximize data availability, performance and capacity.HPE SmartMemory, with speeds up to 1866 MHz, prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency. -
Availability, Expandability and Serviceability - A Winning Combination
User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Storage, HPE Smart Socket guides, and tool-less access to components.Provides plenty of room to grow to meet future needs with options for a second processor, PCIe slots, HPE Smart Memory with capacity up to 768GB, and internal storage configurations with up to 24 SFF or 18 LFF hard drives.HPE SmartDrive technology improves serviceability and prevents data loss with features such as icon-based status display and Do Not Remove LED. -
Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
HPE iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HPE iLO, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while decreasing Time-To-Resolution.HPE Insight Online with HPE remote support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE Smart Update, including HPE SUM, SPP and other products, reduces deployment time and update complexity by systematically and securely updating server infrastructure in the data center; in most cases the downtime is limited to a single reboot. -
Energy Efficiency by Design
First in industry to include 3D array of temperature sensors to help precisely control server fans to direct cooling and reduce unnecessary fan power, saving on cooling costs.High efficiency 80 PLUS certified HPE Common Slot Power Supplies provide up to 94% efficiency (Platinum) and support HP's Power Discovery Services.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
- HPE ProLiant ML350p Gen8 Base - tower - Xeon E5-2620V2 2.1 GHz - 8 GB - no HDD
- Server - tower - administrator password, system password, power-on password, serial port I/O control
- Height (Rack Units)
- 5U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V2 / 2.1 GHz (, up to 2.6 GHz, (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel QuickPath Interconnect, Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 3.0 x8 (Smart Array P420i with 512MB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 21.8 cm x 74 cm x 46.2 cm
- 31.9 kg
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower - 5U
- 2-way
- Front Accessible Bays Qty
- 3
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E5-2620V2
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 2.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 384 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, Online Spare Memory, quad channel memory architecture, low-voltage, HP SmartMemory
- Configuration Features
- 1 x 8 GB
- RAM Supported
- PC3-14900 - 384 GB registered , PC3-12800 - 384 GB - low voltage - registered , PC3-14900 - 768 GB Load-Reduced , PC3-14900 - 128 GB unbuffered - Advanced ECC , PC3-12800 - 128 GB - low voltage - unbuffered - Advanced ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated - PCIe 3.0 x8
- Controller Interface Type
- SATA 3Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P420i with 512MB FBWC
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
- Buffer Size
- 512 MB
Optical Storage
- DVD-RW DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
Input Device
- Mouse
Mouse
- Interface
- USB
- Integrated
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 331i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 3 (total) / 2 (free) x external 5.25" x 1/2H , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 24 (total) / 23 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 4 (total) / 4 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x SD card (internal)
- 1 x serial , 1 x VGA , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 10 x USB 2.0 (4 front, 4 rear, 2 internal)
- Administrator password, system password, power-on password, serial port I/O control
- ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 460 Watt
- 80 PLUS Certification
- 80 PLUS Gold
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Ubuntu, Oracle Solaris, Citrix XenServer
- 21.8 cm
- 74 cm
- 46.2 cm
- 31.9 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
