HP ProLiant ML350e Gen8, a dual-socket 5U tower server, delivers essential performance with room to grow, while requiring low upfront investment. It is ideal for growing businesses running file/print, web messaging, and small vertical applications or databases.
Optimized for Price Performance
Intel Xeon processor E5-2400 product family offers best price performance compute and memory; essential for everyday business needs.HP Smart Storage technology is designed to remove storage bottlenecks and turbo-charge data-intensive application performance to accelerate workloads.HP SmartMemory prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency. -
Easy to Expand and Grow with Your Business
Flexible design provides low-cost expansion capabilities as your business grows giving you the flexibility of adding a second processor, additional hard drive space, more memory, and more storage.HP SmartDrives offer more drive options including 24 SFF and 18 LFF drive cages giving you maximum flexibility for increased capacity for your local storage.Maximim expansion with support up to twelve (12) DDR3 1600 MHz DIMMs (192GB max), six PCI Express (PCIe) slots and 10 USB ports. -
Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
HP iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HP iLO, HP Agentless Management, HP Active Health System, HP Intelligent Provisioning, and HP Embedded Remote Support.HP Insight Control provides advanced management capabilities across the lifecycle of your HP ProLiant server infrastructure. HP iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while increasing Time-To-Resolution.HP Insight Online with HP Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HP SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HP Smart Update Manager (HP SUM), and Service Pack for ProLiant (SPP), and other products. -
Lower Overall Cost of Ownership
Less upfront investment while allowing for growth in the future.With embedded remote management technology, on-site server administration expenses are reduced and travel costs are eliminated.The high efficiency redundant power supplies and fans lower power consumption and reduce operational costs on a daily basis.First in industry to include 3D array of temperature sensors to help precisely control server fans to direct cooling and reduce unnecessary fan power, saving on cooling costs.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
- HPE ProLiant ML350e Gen8 Entry - tower - Xeon E5-2403 1.8 GHz - 2 GB - HDD 500 GB
- Server - tower - administrator password, system password, power-on password, serial port I/O control
- Height (Rack Units)
- 5U
- Localisation
- Region: United Kingdom
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2403 / 1.8 GHz (Quad-Core)
- Cache Memory
- 10 MB L3 Cache
- Cache Per Processor
- 10 MB
- RAM
- 2 GB (installed) / 96 GB (max) - DDR3 SDRAM - ECC - PC3L-10600
- Storage Controller
- RAID (SATA 6Gb/s) - PCIe 2.0 (HP Dynamic Smart Array B120i)
- Server Storage Bays
- Non-hot-swap 3.5"
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 21.8 cm x 74 cm x 46.2 cm
- 25.95 kg
- Limited warranty - parts - 3 years , Limited warranty - labour - 1 year
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower - 5U
- 2-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 3
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2403
- Clock Speed
- 1.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- L3 Cache - 10 MB
- 10 MB
RAM
- Installed Size
- 2 GB / 96 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1066 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3L-10600
- Form Factor
- DIMM 240-pin
- Slots
- 12 (Total) / 11 (empty)
- Unbuffered, HP SmartMemory
- Configuration Features
- 1 x 2 GB
- RAM Supported
- 96 GB unbuffered - ECC , 192 GB registered - ECC , 384 GB Load-Reduced - ECC
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID - plug-in card - PCIe 2.0
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B120i
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD-ROM DVD - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC361i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1s, IEEE 802.3az
- Bays
- 3 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" LFF
- Slots
- 12 (total) / 11 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x SD card , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode)
- 1 x serial , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 8 x USB 2.0 (4 front, 4 rear)
- Administrator password, system password, power-on password, serial port I/O control
- ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply
- Voltage Required
- Power Provided
- 460 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 21.8 cm
- 74 cm
- 46.2 cm
- 25.95 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
