HPE HP ProLiant ML310e Gen8 Intel Xeon E3-1240V2 4GB SATA 4
Quicklinx: 9NTLWS00 Mfr#: 674787-031
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
HP ProLiant ML310e Gen8 Server, a single-socket 4U tower, delivers essential availability and expansion needed to accommodate changing business needs. It is ideal for remote sites and corporate branch offices running file/print, web messaging, and small vertical applications or databases.
  • Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
    HP iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HP iLO, HP Agentless Management, HP Active Health System, HP Intelligent Provisioning, and HP Embedded Remote Support.Maximize system uptime and health with HP Systems Insight Manager 7.x, through a centralized management of HP servers, storage and networking.HP Insight Control provides advanced management capabilities across the lifecycle of your HP ProLiant server infrastructure. HP iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while increasing Time-To-Resolution.HP Insight Online with HP Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HP SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HP Smart Update Manager (HP SUM), and Service Pack for ProLiant (SPP), and other products.
  • Continuous Data Protection
    HP SmartMemory prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency. Support for 4 UDIMMs with up to 32GB max capacity.Smart Array options provide businesses RAID mirroring and striping capability to protect critical data while Flash-backed write cache (FBWC) captures and holds data indefinitely in the event of a power loss, equipment failure, human error or virus attacks.HP Smart Drives improve serviceability and prevents data loss with features such as icon-based status display and Do Not Remove LED.ECC memory protects businesses from data loss and unplanned system downtime.
  • Flexible Options to Meet Changing Business Needs
    HP SmartDrives offer more drive options including 8 SFF and 4 LFF drive cages giving you flexibility for increased capacity for your local storage. Support up to 3 TB.It supports 1600MHz DDR3 memory, with up to four DIMMs (32GB max) for maximizing performance.Four PCI Express (PCIe) slots, including two PCIe Generation 3 slots, provide additional I/O performance.Two power supply options enable you to right-size for your server needs, with a choice of a non-redundant, NHP Multi-Output power supply, or a high efficiency 80+ certified HP Common Slot Power Supply providing up to 92% efficiency (Gold).
HPE ProLiant ML310e Gen8 Performance - tower - Xeon E3-1240V2 3.4 GHz - 4 GB - no HDD
Server - tower - administrator password, power-on password
Height (Rack Units)
4U
Region: United Kingdom
Server Scalability
1-way
1 x Intel Xeon E3-1240V2 / 3.4 GHz (3.8 GHz) (Quad-Core)
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 3Gb/s) - PCIe 2.0 (HP Dynamic Smart Array B120i)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200
GigE
17.5 cm x 47.52 cm x 36.82 cm
11.47 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 4U
Server Scalability
1-way
Front Accessible Bays Qty
2
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C204
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture, HP SmartMemory
Configuration Features
1 x 4 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated - PCIe 2.0
Controller Interface Type
SATA 3Gb/s
Storage Controller Name
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
Interface (Bus) Type
PCI Express x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP 330i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x hot-swap 3.5" LFF
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x SD card (internal)
1 x serial , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 9 x USB 2.0 (4 front, 4 rear, 1 internal)
Administrator password, power-on password
ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
Power supply - hot-plug
Installed Qty
1
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
92%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
ENERGY STAR Certified
17.5 cm
47.52 cm
36.82 cm
11.47 kg
10 °C
35 °C
10 - 90% (non-condensing)
