Are you searching for a tower server to meet the requirements of your small to medium-sized growing business? The HPE ProLiant ML150 Gen9 Server is a tower server that delivers exceptional value for a business with a limited budget with a 24-inch chassis depth. Providing dual processor sockets, it provides essential performance with the Intel Xeon E5-2600 v4 processors. Built-in innovations that simplify server deployment and management, your business can continually reap these benefits on a daily basis, with expansion options that enable you to expand as needed, delivering increased business value. The HPE ProLiant ML150 Gen9 Server provides efficiency and productivity for both the small to medium organization that is growing.
Performance to Meet Growing SMB Requirements
The HPE ProLiant ML150 Gen9 Server is designed for the SMB with up to two processors, in a tower form factor that can be rack mounted. Built-in intelligence, with the right balance of storage, performance, efficiency, manageability and with enough headroom for future growth.Supports up to two Intel Xeon E5-2600 v4 processors with up to 18 cores, up to 120W offering both improved performance and efficiency.Help prevent data loss and downtime with enhanced error handling while improving workload performance and power efficiency with up to (16) DIMM slots of HPE DDR4 SmartMemory.Embedded SATA HPE Dynamic Smart Array B140i Controller for boot and data. Choice of HPE Smart Array Controllers for increased performance, data availability and 12 Gb/s SAS technology or HPE Smart HBAs with reliable high-performance SAS connectivity capable of running HBA mode or simple RAID mode.Increased GPU support (two single wide and one double wide GPU card support) to boost performance in graphic and VDI applications for financial services, education, scientific research and medical imaging. -
Efficiency and Expandability to Fit the Needs of Growing, Budget-Conscious Businesses
The HPE ProLiant ML150 Gen9 Server is designed as a dual-socket tower server providing configuration flexibility and expansion options to meet a wide range of different capacities, connectivity, and design requirements.Flexible expansion capacity with (6) PCIe expansion slots, (8) USB ports, and power supply options.Compact server with a 24-inch chassis depth; newly designed and saves precious real estate space and is suitable for your growing business within a compact office environment.Offering expandability with greater capacity with up to (10) Large Form Factor (LFF) disk drives or (16) Small Form Factor (SFF) disk drive options and increased I/O expansion.Improved ambient temperature standard with ASHRAE A3 helps customer reduce cooling expense. -
Infrastructure Management for Essential Server Administration
The HPE ProLiant ML150 Gen9 Server continues to provide a simplified server deployment with tiered management. Businesses continue to reap benefits on a daily basis, while expansion options allow them to grow as needed with HPE Integrated Lights-Out (iLO).Configure with the Unified Extensible Firmware Interface (UEFI) boot mode, provision both locally and remotely with either the Intelligent Provisioning or Scripting Toolkits.Online personalized dashboard for Converged Infrastructure (CI) for health monitoring and support management from within HPE Insight Online.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant). -
Enhanced Serviceability Offerings
The HPE ProLiant ML150 Gen9 Server delivers a new style IT that delivers simplicity and agility needed to manage business investments.Proven HPE ProLiant reliability, exceptional worldwide service 24x7, unparalleled remote management tools that reduce IT travel costs, while increasing time-to-resolution.Worldwide availability, service and support with a complete range of service offerings from installation to extended support.
- HPE ProLiant ML150 Gen9 Base - Xeon E5-2609V3 1.9 GHz - 8 GB - 0 GB
- Server - tower
- Height (Rack Units)
- 5U
- Localisation
- Europe
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2609V3 / 1.9 GHz ( 6-core )
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 256 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
- Storage Controller
- RAID ( SATA 6Gb/s ) ( HP Dynamic Smart Array B140i )
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Networking
- GigE
- Power
- AC 120/230 V ( 50/60 Hz )
- 20 cm x 62 cm x 43.26 cm
- 16.9 kg
- 3 years warranty - on-site ( 1st year only )
- Server
- Product Form Factor
- Tower - 5U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
- Localisation
- Europe
Processor / Chipset
- CPU
- Intel Xeon E5-2609V3 / 1.9 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C610
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 256 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC4-17000 (2133 MHz)
- Form Factor
- DIMM 288-pin
- Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
- Configuration Features
- 1 x 8 GB
- RAM Supported
- PC4-17000 - 256 GB - Load-Reduced , PC4-17000 - 256 GB - registered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B140i
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Monitor
- Monitor Type
- None.
- Integrated
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP 331i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x hot-swap 3.5" LFF
- Slots
- 16 (total) / 15 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 3 PCIe 3.0 x8 - half-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height ( 2 processors must be installed ) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height ( 2 processors must be installed ) , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x VGA , 2 x LAN (Gigabit Ethernet) , 5 x USB 3.0 ( 2 front, 2 rear, 1 internal ) , 3 x USB 2.0 ( 2 rear, 1 internal )
- Administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
- Power supply
- Nominal Voltage
- Power Provided
- 550 Watt
Operating System / Software
- OS Certified
- SuSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Canonical Ubuntu
- Limited warranty - parts - 3 years - response time: next business day , Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 20 cm
- 62 cm
- 43.26 cm
- 16.9 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
