HPE HP ProLiant ML150 Gen9 Intel Xeon E5-2609v3 4GB
Quicklinx: BGLNWS00 Mfr#: 780849-035
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Are you searching for a tower server to meet the requirements of your small to medium-sized growing business? The HPE ProLiant ML150 Gen9 Server is a tower server that delivers exceptional value for a business with a limited budget with a 24-inch chassis depth. Providing dual processor sockets, it provides essential performance with the Intel Xeon E5-2600 v4 processors. Built-in innovations that simplify server deployment and management, your business can continually reap these benefits on a daily basis, with expansion options that enable you to expand as needed, delivering increased business value. The HPE ProLiant ML150 Gen9 Server provides efficiency and productivity for both the small to medium organization that is growing.
  • Performance to Meet Growing SMB Requirements
    The HPE ProLiant ML150 Gen9 Server is designed for the SMB with up to two processors, in a tower form factor that can be rack mounted. Built-in intelligence, with the right balance of storage, performance, efficiency, manageability and with enough headroom for future growth.Supports up to two Intel Xeon E5-2600 v4 processors with up to 18 cores, up to 120W offering both improved performance and efficiency.Help prevent data loss and downtime with enhanced error handling while improving workload performance and power efficiency with up to (16) DIMM slots of HPE DDR4 SmartMemory.Embedded SATA HPE Dynamic Smart Array B140i Controller for boot and data. Choice of HPE Smart Array Controllers for increased performance, data availability and 12 Gb/s SAS technology or HPE Smart HBAs with reliable high-performance SAS connectivity capable of running HBA mode or simple RAID mode.Increased GPU support (two single wide and one double wide GPU card support) to boost performance in graphic and VDI applications for financial services, education, scientific research and medical imaging.
  • Efficiency and Expandability to Fit the Needs of Growing, Budget-Conscious Businesses
    The HPE ProLiant ML150 Gen9 Server is designed as a dual-socket tower server providing configuration flexibility and expansion options to meet a wide range of different capacities, connectivity, and design requirements.Flexible expansion capacity with (6) PCIe expansion slots, (8) USB ports, and power supply options.Compact server with a 24-inch chassis depth; newly designed and saves precious real estate space and is suitable for your growing business within a compact office environment.Offering expandability with greater capacity with up to (10) Large Form Factor (LFF) disk drives or (16) Small Form Factor (SFF) disk drive options and increased I/O expansion.Improved ambient temperature standard with ASHRAE A3 helps customer reduce cooling expense.
  • Infrastructure Management for Essential Server Administration
    The HPE ProLiant ML150 Gen9 Server continues to provide a simplified server deployment with tiered management. Businesses continue to reap benefits on a daily basis, while expansion options allow them to grow as needed with HPE Integrated Lights-Out (iLO).Configure with the Unified Extensible Firmware Interface (UEFI) boot mode, provision both locally and remotely with either the Intelligent Provisioning or Scripting Toolkits.Online personalized dashboard for Converged Infrastructure (CI) for health monitoring and support management from within HPE Insight Online.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
  • Enhanced Serviceability Offerings
    The HPE ProLiant ML150 Gen9 Server delivers a new style IT that delivers simplicity and agility needed to manage business investments.Proven HPE ProLiant reliability, exceptional worldwide service 24x7, unparalleled remote management tools that reduce IT travel costs, while increasing time-to-resolution.Worldwide availability, service and support with a complete range of service offerings from installation to extended support.
HPE ProLiant ML150 Gen9 - tower - Xeon E5-2609V3 1.9 GHz - 4 GB - no HDD
Server - tower - administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon E5-2609V3 / 1.9 GHz (6-core)
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
4 GB (installed) / 256 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
GigE
20 cm x 62 cm x 43.26 cm
16.9 kg
Manufacturer Selling Program
HP Top Value
Limited warranty - parts - 3 years , Limited warranty - labour - 1 year - on-site
Server
Product Form Factor
Tower - 5U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
1.9 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
4 GB / 256 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total)
Registered, Online Spare Memory, HP SmartMemory
RAM Supported
PC4-17000 - 256 GB Load-Reduced , PC4-17000 - 256 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Integrated
Remote Management Protocol
IPMI 2.0, SMASH CLP
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
16 DIMM 288-pin , 2 (total) / 1 (free) x CPU , 3 (total) / 3 (free) x PCIe 3.0 x8 - half-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (x16 mode) , 1 (total) / 1 (free) x microSD Card (internal)
1 x LAN (Gigabit Ethernet) , 2 x HPE iLO , 4 x USB 3.0 , 2 x USB 2.0
Administrator password, power-on password, serial port I/O control, Setup Password, UEFI BIOS
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
HP Top Value
Power supply
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Silver
Efficiency
89%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer, Canonical Ubuntu
20 cm
62 cm
43.26 cm
16.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
BGLN C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
