Do you need an affordable storage server for capacity intensive applications? The HPE ProLiant DL80 Gen9 Server is designed with affordable storage, networking, processor scalability, and manageability in a 2U server for cost conscious service provider and SMBs. Apart from basic IT infrastructure workloads this server is ideal for running storage capacity intensive applications like cold storage and back-up due to the compelling cost/GB that it offers.
Affordable Storage and IO Expandability for Service Providers and SMBs
The HPE ProLiant DL80 Gen9 Server provides ample storage capacity with up to (12) Large Form Factor (LFF) HPE SmartDrives, delivering optimal performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics.Up to (6) PCIe 3.0 riser slots to support one single-wide GPU or networking cards offering increased IO bandwidth and seamless expandability.Comes standard with 2x1GbE and choice of HPE FlexibleLOM to provide you flexibility of networking bandwidth and fabric so you can adapt to changing business needs.With support for Large Form Factor (LFF) hard disk drives (HDDs) with up to 10 TB capacity DL80 Gen9 offers maximum storage of up to 120 TB SAS/SATA. -
Just Enough Performance for Basic IT Infrastructure Workloads
The HPE ProLiant DL80 Gen9 Server supports up to two (2) Intel Xeon processor E5-2600 v4 processors offering improved performance and efficiency.HPE SmartMemory has the built-in intelligence to improve performance, reduce downtime and energy costs resulting in up to 14% better throughput performance and up to 37% lower power consumption with DDR4 memory.Embedded SATA HPE Dynamic Smart Array B140i Controller for boot and data. Choice of HPE Smart Array Controllers with increased performance, data availability with 12 Gb/s SAS technology or HPE Smart HBAs with reliable high performance SAS connectivity capable of running HBA mode or simple RAID mode. -
Agile Infrastructure Management for Accelerating IT Service Delivery
Included with the HPE ProLiant DL80 Gen9 Server is HPE OneView providing infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for Converged Infrastructure (CI) health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits or HPE RESTful Interface Tool for increased flexibility.Embedded management to deploy, monitor and support your server remotely, out of band with HPE Integrated Lights-Out (iLO).Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant). -
Energy Efficiency by Design
HPE ProLiant DL80 Gen9 Server with 80 PLUS gold certified entry-level redundant HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption and expense.Improved ambient temperature standard with ASHRAE A3 helps customers reduce cooling expense.
- HPE ProLiant DL80 Gen9 - rack-mountable - Xeon E5-2603V3 1.6 GHz - 4 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, UEFI BIOS
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2603V3 / 1.6 GHz (6-core)
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 4 GB (installed) / 128 GB (max) - DDR4 SDRAM - Advanced ECC
- Storage Controller
- RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200eH2
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 44.55 cm x 60.7 cm x 8.75 cm
- 16.59 kg
- Manufacturer Selling Program
- HP Top Value
- Limited warranty - parts and labour - 1 year - on-site
- Server
- Product Form Factor
- Rack-mountable - 2U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon E5-2603V3
- Clock Speed
- 1.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 4 GB / 128 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 7 (empty)
- Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
- Configuration Features
- 1 x 4 GB
- RAM Supported
- 128 GB registered , 256 GB Load-Reduced
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B140i
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200eH2
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC361i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
- Bays
- 8 (total) / 8 (free) x hot-swap 3.5" LFF
- Slots
- 2 (total) / 1 (free) x CPU , 8 (total) / 7 (free) x DIMM 288-pin , 3 (total) / 3 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x microSD Card (internal)
- 2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
- Administrator password, power-on password, UEFI BIOS
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 4943, GB 9254, ASHRAE, CNS 13438, BSMI CNS 14336-1
- HP Top Value
- Power supply
- Voltage Required
- Power Provided
- 550 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- 44.55 cm
- 60.7 cm
- 8.75 cm
- 16.59 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
