HPE ProLiant DL580 Gen8 Intel Xeon E7-4850 128GB (16x8GB) NO HDD
Quicklinx: 9NSCWS00 Mfr#: 728546-421
  • Xeon
  • Red Hat Enterprise Linux
Does your enterprise data center demand uncompromised performance and cutting-edge resiliency at a lower total cost of ownership? The HP ProLiant DL580 Gen8 Server is an enterprise-grade four socket (4S) x86 server offering breakthrough performance, rock-solid reliability, and compelling consolidation and manageability efficiencies. It is ideal for mission-critical enterprise, business intelligence, and database applications. Featuring Intel Xeon E7-4800 v2 processors, the HP DL580 Gen8 offers blazing fast results with enhanced processor performance, more memory slots (96 DIMMs), greater IO bandwidth (9 PCIe Gen3.0 slots), and increased storage performance (12 Gbps SAS) over the HP DL580 G7 systems. HP ProLiant DL580 Gen8 has security and data protection features for system resiliency that your business can depend on. With intelligent manageability through HP OneView, iLO 4, and user-inspired features, you get faster, lower cost infrastructure management.
  • Breakthrough Performance and Scalability
    The HPE ProLiant DL580 Gen8 Server provides up to 2x processor performance and 50% more cores with Intel Xeon E7-4800 v2 processors than the previous generation.Allows you to implement large-scale in-memory computing and virtualization with more memory slots (96 DIMMs).Supports more PCIe flash storage or co-processor cores to boost performance with greater I/O bandwidth: 9 PCIe Gen3 slots including 5 x16 FL/FH slots.Increases SSD performance with 12 Gbps HPE Smart Array SAS Controllers and greater internal storage capacity for faster access to more data.
  • Leading Availability and Reliability
    The HPE ProLiant DL580 Gen8 Server provides increased system availability and less need for service with enhanced error recovery, improved error diagnosis, and built-in redundancy.Improves reliability and data protection with HPE Smart Array Controllers featuring 4 G cache, Advanced Data Mirroring, and HPE SmartDrive technology.Increases security with support for Unified Extensible Firmware Interface (UEFI) mode, Secure Boot, HPE Secure Encryption, and Intel Secure Key.HPE Proactive Care Services integrates uptime and productivity into a personalized, simplified support experience.
  • Compelling Efficiencies with Intelligent Manageability and Scale-up Consolidation
    The HPE ProLiant DL580 Gen8 Server provides total cost of ownership savings with scale-up consolidation efficiencies and software licensing cost savings.Faster, lower-cost infrastructure management and a single integrated view of your IT infrastructure with HPE OneView.Provides up to 3x faster administrative updates with 93% less downtime and 69% less operator time through industry-leading maintenance tools with HPE Smart Update Manager (SUM).Comprehensive embedded manageability with HPE iLO 4, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.User-inspired features such as FlexibleLOM for a choice in networking, front access processor/memory drawer for ease of serviceability, and QR code for quick access to product information.
HPE ProLiant DL580 Gen8 High Performance - rack-mountable - Xeon E7-4850V2 2.3 GHz - 128 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, USB port control, 80 PLUS Platinum Plus
Height (Rack Units)
4U
Region: Europe
Server Scalability
4-way
4 x Intel Xeon E7-4850V2 / 2.3 GHz (, up to 2.8 GHz, (12-core)
Cache Memory
96 MB L3 Cache
Cache Per Processor
24 MB
RAM
128 GB (installed) / 3 TB (max) - DDR3 SDRAM - PC3-14900
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 2.0 x4 (Smart Array P830i with 2GB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
10GbE
Power Redundancy
Software Included
HP Insight Control
48.3 cm x 70 cm x 17.6 cm
30 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 4U
Embedded Security
Trusted Platform Module (TPM) Security Chip
Server Scalability
4-way
Hot-Swap Bays Qty
10
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
12-core
CPU Qty
4
Max CPU Qty
4
CPU Upgradability
Upgradable
Chipset Type
Intel C602J
Cache Memory
Installed Size
L3 Cache - 96 MB
Cache Per Processor
24 MB
RAM
Installed Size
128 GB / 3 TB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC3-14900
DIMM 240-pin
Slots
96 (Total) / 80 (empty)
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
Configuration Features
16 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Plug-in card
Interface (Bus) Type
FlexibleLOM
Ethernet Ports
2 x 10 Gigabit Ethernet
Ethernet Controller
HP FlexFabric 534FLR-SFP+
10 Gigabit Ethernet
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau, IEEE 802.1Qbg, IEEE 802.2x
Bays
10 (total) / 10 (free) x hot-swap 2.5" SFF
Slots
96 (total) / 80 (free) x DIMM 240-pin , 4 (total) / 0 (free) x CPU , 5 (total) / 5 (free) x PCIe 3.0 x16 - full-length, full-height , 4 (total) / 4 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode) , 1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x microSD Card
1 x serial , 2 x VGA (1 front, 1 rear) , 1 x HPE iLO , 8 x USB 2.0 (2 front, 4 rear, 2 internal) , 2 x LAN (10Gigabit Ethernet) (SFP+)
Rack rail kit
Administrator password, power-on password, keyboard password, serial port I/O control, USB port control, 80 PLUS Platinum Plus
ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
2+2
Installed Qty
4
Max Supported Qty
4
Power Provided
1500 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
Software
HP Insight Control
48.3 cm
70 cm
17.6 cm
30 kg
10 °C
35 °C
10 - 90% (non-condensing)
