Are you looking to expand your data center with a cost-effective two socket server blade offering exceptional price/performance in a half-height form factor? The ProLiant BL465c Gen8 Server Blade provides a unique blend of core density combined with a broad memory footprint in a half-height form factor that delivers unparalleled price/performance leadership for virtualization, IT infrastructure, database, and high-performance computing (HPC) environments. With up to 512 cores in a single enclosure and up to 2048 cores in a single rack, these servers provide very dense deployment for your data center. Innovations in performance, flexibility in networking options, and robust management features make this the ideal 2-socket server blade for midmarket and enterprise data centers.
Redefining the Customer Experience
The user-inspired design features of the HP ProLiant BL465c Gen8 Server Blade anticipate your needs and virtually eliminate common issues that result in downtime.Integrated Lifecycle Automation, an industry first, provides embedded provisioning tools, Active Health monitoring, and system maintenance capabilities standard on all ProLiant servers using the industry-leading HP iLO Management Engine.Dynamic Workload Acceleration delivers smarter data protection for ever-increasing drive capacities, real-time workload-aware analysis to optimize and adapt storage performance, and 6X faster solid state performance versus previous generation.Automated Energy Optimization improves the server's ability to analyze and respond to "3D Sea of Sensors" data within the server as well as self-identify location and inventory through HP Insight Control for maximum workload optimization across the entire data center. -
Intuitive, Automated System Management Reduces Tedious, Time-Consuming Tasks
HP Intelligent Provisioning is a single embedded tool for all server set-up and configuration tasks. All of the firmware, drivers, and tools that you need to quickly get your systems online are built into Gen8 servers - no more CDs or DVDs needed.HP Active Health provides 24x7 continuous agentless health monitoring and alerting and 100% configuration change logging. Start problem analysis faster using unified diagnostic tools with secure data transfer to HP Service and Support.Smart Update is a breakthrough system maintenance tool with one-click simplicity that systematically updates firmware and system software across servers and blade infrastructures at the scale of your data center. -
Improved Application, Storage, and I/O Performance
HP SmartMemory provides unmatched performance, quality and manageability advantages above industry standard memory, with support for up to 512 GB capacity at 1333 MHz and up to 256 GB at 1600 MHz.The integrated HP Smart Array P220i RAID controller with 512 MB Flash Backed Write Cache supports HP Smart Storage and HP SmartDrives. Choice of two (2) 2.5-inch SFF SAS, SATA, or SSD drives.BL465c Gen8 1x8 and 1x16 I/O expansion slots support the highest performing mezzanine option cards and provide I/O bandwidth improvements over the previous generation.HP FlexibleLOM provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware. Provides choice of bandwidth and fabric (Ethernet, FCoE, InfiniBand), and supports wake on LAN (WOL). -
Built for Performance, Efficiency, and Serviceability
AMD Opteron 6300 Series Processors provide new levels of performance and efficiency over the previous generation.The Health Status LED on the server blade and the Location LED on the HP Smart Drives allow for quick visibility to issues or blades that need to be located and serviced.Improved efficiency with support for 1.25V ULV and 1.35 LV HP SmartMemory.Improved access to mezzanine cards enables quicker removal and easy access to the new FlexibleLOM card. The FlexibleLOM was designed with easy lift and remove handles.
- HPE ProLiant BL465c Gen8 - blade - Opteron 6344 2.6 GHz - 16 GB - no HDD
- Server - blade - administrator password, power-on password, keyboard password, USB port control, quick lock
- Server Scalability
- 2-way
- Processor
- 1 x AMD Opteron 6344 / 2.6 GHz (3.2 GHz) (12-core)
- Cache Memory
- 16 MB L3 Cache
- Cache Per Processor
- 16 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR3 SDRAM
- Storage Controller
- SAS-2 (SAS 6Gb/s) - PCIe x4 (Smart Array P220i with 512MB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE, 10 GigE, FCoE
- 5.54 cm x 51.76 cm x 18.07 cm
- 4.75 kg
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Blade
- 2-way
- Hot-Swap Bays Qty
- 2
Processor / Chipset
- CPU
- AMD Opteron 6344
- Clock Speed
- 2.6 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 12-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD SR5690/SP5100
Cache Memory
- Installed Size
- L3 Cache - 16 MB
- 16 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 16 (Total) / 14 (empty)
- Registered, HP SmartMemory
- Configuration Features
- 2 x 8 GB
- RAM Supported
- PC3-10600 - 512 GB Load-Reduced , PC3-12800 - 256 GB registered
Hard Drive
- No HDD
Storage Controller
- 1 x SAS-2 - integrated - PCIe x4
- Controller Interface Type
- SAS 6Gb/s
- Storage Controller Name
- Smart Array P220i with 512MB FBWC
- RAID Level
- RAID 0, RAID 1
- Buffer Size
- 512 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Interface (Bus) Type
- FlexibleLOM
- Ethernet Ports
- 2 x 10 Gigabit Ethernet
- Ethernet Controller
- HP 554FLB
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet, Fibre Channel over Ethernet (FCoE)
- Remote Management Protocol
- SNMP, IPMI 2.0
- Remote Management Controller
- Integrated Lights-Out 4
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3ap
- Bays
- 2 (total) / 2 (free) x hot-swap 2.5" SFF
- Slots
- 2 (total) / 1 (free) x CPU , 16 (total) / 14 (free) x DIMM 240-pin , 1 (total) / 1 (free) x expansion slot (x8 mode) , 1 (total) / 1 (free) x expansion slot (x16 mode) , 1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x microSDHC Card
- 2 x LAN (10Gigabit Ethernet) , 1 x HPE iLO
- Administrator password, power-on password, keyboard password, USB port control, quick lock
- ACPI 2.0, WEEE
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer
- 5.54 cm
- 51.76 cm
- 18.07 cm
- 4.75 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
