Are you looking for breakthrough server blade economics for your enterprise workloads? The HP ProLiant BL420c Gen8 Server Blade, an entry level dual-socket half-height offering in the HP blade server portfolio, is designed for cost-optimized performance, high availability, and enterprise-level management. It delivers up to 384 GB of memory and 1600 MHz speeds. It offers 12 DIMMs, flexible networking options via FlexibleLOMs, enhanced I/O expansion slots, and two choices of Smart Array controllers, delivering the performance and versatility needed in an enterprise data center. The BL420c Gen8 Server Blade supports the HP iLO Management Engine, a set of embedded management features supporting the complete lifecycle of the server, from initial deployment, through ongoing management, to service alerting and remote support. It includes: HP iLO, HP Intelligent Provisioning (previously known as SmartStart), HP Agentless Management, HP Active Health System, and HP embedded Remote Support.
Redefining the Customer Experience
The user-inspired design features of the HP ProLiant BL420c Gen8 Server Blade anticipate your needs and virtually eliminate common issues that result in downtime.Integrated Lifecycle Automation, an industry first, provides embedded provisioning tools, Active Health monitoring, and system maintenance capabilities standard on all ProLiant servers and built using the industry-leading HP iLO Management Engine.Dynamic Workload Acceleration delivers smarter data protection for ever-increasing drive capacities, real-time workload-aware analysis to optimize and adapt storage performance, and 6X faster solid state performance versus previous generation.Automated Energy Optimization improves the server's ability to analyze and respond to "3D Sea of Sensors" data within the server as well as self-identify location and inventory through HP Insight Control for maximum workload optimization across the entire data center. -
Intuitive, Configurable Management System Eliminates Tedious, Time-Consuming Tasks
HP Intelligent Provisioning is a single embedded tool for all server set-up and configuration tasks. All of the firmware, drivers, and tools that you need to quickly get your systems online are built into Gen8 servers - no more CDs or DVDs needed.HP Active Health provides 24x7 continuous agentless health monitoring and alerting and 100% configuration change logging. Start problem analysis faster using unified diagnostic tools with secure data transfer to HP Service and Support.Smart Update is a breakthrough system maintenance tool with one-click simplicity that systematically updates firmware and system software across servers and blade infrastructures at the scale of your data center. -
Improved Application, Storage, and I/O Performance
HP SmartMemory provides unmatched performance, quality and manageability advantages above industry standards memory with support up to 384GB capacity at 1600 MHz. With SmartMemory, the BL420c Gen8 delivers up to 33% more memory capacity over previous generations.Storage Controller choices between HP Dynamic Smart Array B320i Controller with options for cache and SAS license upgrades OR HP Smart Array P220i controller with 512MB Flash Backed Write Cache supports HP Smart Storage and HP SmartDrives. Choice of two (2) 2.5-inch SFF SAS, SATA, SSD drives.PCIe 3.0 technology provides improved latency and up to 400% the bandwidth per I/O expansion slot compared to ProLiant BL280c G6. The server's x16 PCIe 3.0 Type B I/O expansion slot supports the highest performing mezzanine option cards, now and into the future.HP FlexibleLOM provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware. Provides choice of bandwidth and fabric (Ethernet, FCoE, InfiniBand), supports WOL, and provides a shared iLO port for ease of use. -
Built for Performance and Serviceability
Intel Xeon E5-2400 v2 Series Processors provide new levels of performance over the previous generation.The Health Status LED on the server blade and the Location LED on the HP Smart Drives allow for quick visibility to issues or blades that need to be located and serviced.The HP Smart Socket Guide provides ease and simplicity of processor installation or upgrade.Improved access to mezzanine cards enables quicker removal and easy access to the new FlexibleLOM card. The DIMM tool included inside every ProLiant BL420c Gen8 makes the removal and insertion of individual DIMMs even easier.
- HPE ProLiant BL420c Gen8 - blade - Xeon E5-2430 2.2 GHz - 12 GB - no HDD
- Server - blade
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2430 / 2.2 GHz (2.7 GHz) (6-core)
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 12 GB (installed) / 192 GB (max) - DDR3 SDRAM - PC3-10600
- Storage Controller
- SAS-2 (SATA 6Gb/s / SAS 6Gb/s) - PCIe 3.0 x8 (HP Dynamic Smart Array B320i)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE
- 5.54 cm x 51.76 cm x 18.7 cm
- 4.75 kg
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Blade
- 2-way
- Hot-Swap Bays Qty
- 2
Processor / Chipset
- CPU
- Intel Xeon E5-2430
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- 6-core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 12 GB / 192 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 12 (Total) / 9 (empty)
- Registered, HP SmartMemory
- Configuration Features
- 3 x 4 GB
- RAM Supported
- PC3-10600 - 384 GB Load-Reduced , PC3-12800 - 192 GB registered , PC3-10600 - 96 GB unbuffered
Hard Drive
- No HDD
Storage Controller
- 1 x SAS-2 - integrated - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B320i
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Interface (Bus) Type
- FlexibleLOM
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP 361FLB
- Data Link Protocol
- Remote Management Protocol
- SNMP, IPMI 2.0
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as
- Bays
- 2 (total) / 2 (free) x hot-swap 2.5" SFF
- Slots
- 2 (total) / 1 (free) x CPU , 12 (total) / 9 (free) x DIMM 240-pin , 1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x expansion slot (x16 mode) , 1 (total) / 1 (free) x expansion slot (x8 mode) , 1 (total) / 1 (free) x microSDHC Card
- 1 x LAN (Gigabit Ethernet) , 1 x HPE iLO
- ACPI 2.0, WEEE
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- 5.54 cm
- 51.76 cm
- 18.7 cm
- 4.75 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
