Simplify and make your data center change-ready. The HP Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem is a new class of blade interconnect that simplifies server connections by cleanly separating the server enclosure from the SAN. It simplifies networks by reducing cables without adding switches to manage, and it allows you to change servers or move workloads in just minutes. You can reduce costs and simplify connections to LANs and SANs, consolidate your network connections and enable administrators to add, replace and recover server resources on-the-fly. The standards-based Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem looks like a pass-thru device to the network, yet provides all the key benefits of integrated switching including high performance 8 Gb uplinks to the SAN. The integrated design frees up rack space, reduces power and cooling requirements, and reduces cables and small form-factor pluggable transmitters.
Standard Based
HP Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem is compatible with all other NPIV standards-based switch products. This provides high performance, end-to-end connections with your favorite brands of core switches.HP Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem appears as a pass-thru device to the network. Any changes to the server are transparent to its associated network, cleanly separating the servers from SAN and relieving SAN Administrators from server maintenance.HP Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem has an embedded Virtual Connect Manager that runs on each Virtual Connect Module. You can define available SANs, LAN's, server connections, and manage server connection profiles.
- HPE Virtual Connect 8Gb 24-Port Fibre Channel Module - switch - 24 ports - plug-in module
- Switch - 24 ports
- Enclosure Type
- Plug-in module
- Subtype
- Fibre Channel
- Ports
- 24 x 8Gb Fibre Channel
- Auto-negotiation, manageable
- 26.8 cm x 9.3 cm x 2.8 cm
- 1.27 kg
- 1-year warranty
- Designed For
- BLc3000 Enclosure; BLc3000 Single-Phase Enclosure; BLc7000 Enclosure; BLc7000 Enclosure Model X; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant c3000
- Switch - 24 ports
- Enclosure Type
- Plug-in module
- Subtype
- Fibre Channel
- Compatible Slots
- 1 x Expansion Slot
- Ports
- Fibre Channel
- FC-AL, FC-AL-2, FC-FG, FC-FLA, FC-GS, FC-GS-2, FC-GS-3, FC-PH, FC-PH-2, FC-PH-3, FC-VI
- Status Indicators
- Port status, link OK, module locator, link/activity
- 16 x 8Gb Fibre Channel - backplane , 2 x 8Gb Fibre Channel - LC , 6 x SFP+
- VCCI, AS/NZ 3548 Class A, UL 60950-1, EN 60950-1, WEEE, FCC Part 15 A, MIC Class A, EN 55022 Class A
- 26.8 cm
- 9.3 cm
- 2.8 cm
- 1.27 kg
- Limited warranty - parts and labour - 1 year - on-site
- 10 °C
- 35 °C
- 10 - 90%
- Designed For
- HPE BLc3000 Enclosure , HPE BLc3000 Single-Phase Enclosure , HPE BLc7000 Enclosure , HPE BLc7000 Enclosure Model X , HPE BLc7000 Single-Phase Enclosure , HPE BLc7000 Three-Phase Enclosure , HPE ProLiant c3000
