Product
Brand
HPE HP ProLiant BL cClass ProCurve 6120XG (10GBe) Switch Module Kit
Quicklinx: 7VH6WS00 Mfr#: 516733-B21
The HP 6120XG Ethernet Blade Switch is designed for the c-Class Blade System and HP Integrity Superdome 2 enclosures that provides enhanced Layer 2 features and interoperability across existing network environments. Reduce complexity of network management through resilient edge-to-core connectivity and automated provisioning. The 6120XG offers a variety of connection interfaces and robust high-availability features that offers investment protection, flexibility, and scalability.
HPE 6120XG Blade Switch - switch - 8 ports - Managed - plug-in module
Switch - 8 ports - Managed
Enclosure Type
Plug-in module
Subtype
10 Gigabit Ethernet
Ports
16 x 10Gb Ethernet (midplane downlink) + 2 x 10Gb Ethernet (cross connect link) + 1 x 10GBase-CX4 (uplink) + 8 x 10 Gigabit SFP+ (uplink)
Performance
Forwarding performance (64-byte packet size): 357.1 Mpps , Latency: 1.8 µs
Layer 2 multicast groups: 256
MAC Address Table Size
16K entries
Jumbo Frame Support
9220 bytes
Routing Protocol
RIP-2, static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, DHCP support, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, port mirroring, IPv6 support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), STP Root Guard, dynamic ARP protection, Dynamic VLAN Support (GVRP)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v
19.279 cm x 26.77 cm x 2.794 cm
1.27 kg
BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant c3000
Enclosure Type
Plug-in module
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9220 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS, TACACS+, Secure Shell v.2 (SSH2)
RAM
512 MB
Flash Memory
640 MB Flash
Status Indicators
Unit ID, link/activity
Network node: 16 x 10Gbit LAN midplane downlink , 2 x 10Gbit LAN 10GBase-CX4 cross connect link , 8 x 10Gbit LAN SFP+ - SFP+ uplink , 1 x 10GBase-CX4 uplink , 1 x USB management
105 Watt
FCC Class A certified, UL, EN55022, VCCI Class A ITE, EN55024, MIC, ICES-003 Class A, UL 60950-1, EN 60950-1, WEEE, RoHS, AS/NZS 3548 Class A, CAN/CSA C22.2 No. 60950-1
19.279 cm
26.77 cm
2.794 cm
1.27 kg
10 °C
35 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
60 °C
HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE ProLiant c3000
