HPE Premier Flex LC/LC OM4 2F Fibre Optic Cable
Quicklinx: BQDLWS00 Mfr#: QK735A
£138.51 ex VAT
£166.21 inc VAT
Provide more robust and reliable data transfer, due to their lower sensitivity to sharp bends, which can reduce downtime and operating expense.
Fiber optic cable routing can result in 90° bends, cables caught in cabinet doors and kinks. Data loss and transmission errors resulting from these common problems are difficult to troubleshoot, expensive, and increase downtime. HP PremierFlex bendable fiber optic cables solve these problems by providing up to 10 times better bend performance than existing fiber cables.
HP's PremierFlex cables use a bendable fiber technology that significantly improves bend performance over existing fiber cables. This, combined with improvements in fiber clarity and bandwidth, allows HP PremierFlex cables to transmit data over longer distances, at higher rates, with fewer transmission errors.
  • Significantly improved performance under acute bend
    It is 135% higher bandwidth and less modal dispersion than standard OM3 cables, and 840% higher bandwidth vs. standard OM2 cables.
  • Lower maintenance cost
    Less susceptible to signal loss in typical routing applications, which means more up-time, less troubleshooting, and lower operating expense.
  • Efficient use of space
    Tolerant of tighter bends needed in compact applications.
  • Reliability insurance
    Provide signal reliability and peace of mind.
  • Simplified installation
    It can be handled more intuitively.
  • Significantly better signal quality
    They have 112% better signal quality than standard OM2/OM3 fiber cables.
HPE Premier Flex - network cable - 15 m
Network cable - OM4
Fibre optic
Type of Fibre Optics
Multimode
Length
15 m
Connector
2 x LC multi-mode - male
Connector (Second End)
Brocade 16Gb/12, 16Gb/24; HPE 3600, 8/24, 8/8, SN3600B 32, SN6000, SN6610C 32, SN6710C 64, SN6720C 64, SN6750, SN8500C/SN8700C 48, SN8700C 64; StoreFabric SN3600, SN4000, SN6500, SN6600B 32, SN6610, SN6620C 24, SN6650, SN8600B 4-slot; HPE Aruba 2920, 2930F 24, 2930F 48, 2930M 24, 5406
Network Cable Type
Network cable - OM4
Fibre optic
Multimode
Fibre Qty
2
Length
15 m
Connector
Brocade 16Gb/12 SAN Switch Module for HPE Synergy, 16Gb/24 Fibre Channel SAN Switch Module for HPE Synergy, 16Gb/24 SAN Switch Module Power Pack+ for HPE Synergy , HPE 3600-24 v2 EI, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP v2 EI, 3600-48-PoE+ v2 SI, 8/24 Base (16) Full Fabric Ports Enabled SAN, 8/8 Base (0) e-port SAN, SN3600B 32Gb 24/8 8-port 16Gb Short Wave SFP+ Fibre Channel Switch, SN6000B, SN6610C 32Gb 32/24 32Gb Short Wave SFP+ Fibre Channel Switch, SN6610C 32Gb 32/24 32Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6710C 64Gb 24/8 32Gb Short Wave SFP+ Fibre Channel Switch, SN6710C 64Gb 24/8 32Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6710C 64Gb 24/8 64Gb Short Wave SFP+ Fibre Channel Switch, SN6710C 64Gb 24/8 64Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6710C 64Gb 24/8 Fibre Channel Switch, SN6720C 64Gb 48/24 32Gb Short Wave SFP+ Fibre Channel Switch, SN6720C 64Gb 48/24 32Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6720C 64Gb 48/24 64Gb Short Wave SFP+ Fibre Channel Switch, SN6720C 64Gb 48/24 64Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6720C 64Gb 48/24 Fibre Channel Switch, SN6750B, SN6750B Port Side Intake, SN8500C/SN8700C 48-port 32Gb Fibre Channel Director Module, SN8700C 64Gb 48-port 32Gb SFP+ Fibre Channel Director Module, SN8700C 64Gb 48-port Fibre Channel Director Module , HPE StoreFabric SN3600B, SN3600B Power Pack+, SN4000B Power Pack+ SAN Extension Switch, SN6500B Power Pack+, SN6600B 32Gb 48/24, SN6600B 32Gb 48/24 Power Pack+, SN6600B 32Gb 48/48, SN6600B 32Gb 48/48 Power Pack+ Fibre Channel Switch, SN6610C, SN6620C 24-port 32Gb SFP+ Fibre Channel Switch, SN6650B, SN6650B Power PAck, SN8600B 4-slot Power Pack+ Director Switch , HPE Aruba 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 2930M 24 Smart Rate POE+ 1-Slot, 5406 zl
