Your basket is empty
HPE HP Premier Flex LC/LC OM4 2F Fibre Optic Cable
Quicklinx: BQDLWS00 Mfr#: QK735A
Length: 15m
£174.05 ex VAT
£208.86 inc VAT
Provide more robust and reliable data transfer, due to their lower sensitivity to sharp bends, which can reduce downtime and operating expense.
Fiber optic cable routing can result in 90° bends, cables caught in cabinet doors and kinks. Data loss and transmission errors resulting from these common problems are difficult to troubleshoot, expensive, and increase downtime. HP PremierFlex bendable fiber optic cables solve these problems by providing up to 10 times better bend performance than existing fiber cables.
HP's PremierFlex cables use a bendable fiber technology that significantly improves bend performance over existing fiber cables. This, combined with improvements in fiber clarity and bandwidth, allows HP PremierFlex cables to transmit data over longer distances, at higher rates, with fewer transmission errors.
HPE PremierFlex - network cable - 15 m
Network cable - OM4
Fibre optic
Length
15 m
Connector
2 x LC multi-mode - male
Connector (Second End)
Aruba 2920, 2930F 24, 2930F 48, 5406; HP 3100; HPE 12504, 1810, 3600, 5500, 8/20, 8/24, 8Gb, MSL2024, MSL4048, SAN Switch 8/80, SN8000B 32; 1/8 G2 Tape Autoloader; Enterprise Virtual Array P6350; Modular Smart Array 1040, 2040, 2040 10, P2000 G3; ProLiant DL360e Gen8; StoreFabric 8/24 8Gb
Network Cable Type
Network cable - OM4
Fibre optic
Fibre Qty
2
Length
15 m
Connector
Aruba 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl , HP 3100-8-PoE v2 EI Switch , HPE 12504 AC Switch Chassis, 1810-24 v2, 1810-8G v2 Switch, 1910-8G Switch, 3100-24 V2 EI Switch, 3100-24-PoE v2 EI Switch, 3100-8 v2 SI Switch, 32-port 16Gb/s Director Blade, 32-port 8Gb/s Director Blade, 3600-24 v2 EI Switch, 3600-24-PoE+ v2 EI Switch, 3600-24-PoE+ v2 SI Switch, 3600-24-SFP v2 EI Switch, 3600-48-PoE+ v2 SI Switch, 48-port 16Gb/s Director Blade, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 8/20q Fibre Channel Switch, 8/24 Base (16) Full Fabric Ports Enabled SAN Switch, 8/8 (8) Full Fabric Ports Enabled SAN Switch, 8/8 Base (0) e-port SAN Switch, 8Gb Simple SAN Connection Kit, MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760, SAN Director 64-port 8Gb Fibre Channel Blade, SAN Switch 8/80 Power Pack+, SN3000B 16Gb 24-port/24-port Active Fibre Channel Switch, SN6000B 16Gb 48-port/24-port Active Fibre Channel Switch, SN8000B 32-port 8Gb/s Director Blade, SN8000B 48-port 8Gb/s Director Blade , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE Enterprise Virtual Array P6350 FC SFF Combo Field Kit , HPE Modular Smart Array 1040 Dual Controller LFF Storage, 1040 Dual Controller SFF Bundle, 1040 Dual Controller SFF Storage, 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAS Dual Controller LFF Storage, 2040 SAS Dual Controller SFF Bundle, P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE ProLiant DL360e Gen8, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server , HPE StoreFabric 8/24 8Gb Bundled Fibre Channel Switch
Length: 15m
Brand: HPE
Price Range Ex VAT: 150 - 300
