Product
Brand
HPE HP Power Supply 495W Hot-plug – Kit
Quicklinx: 9NKWWS00 Mfr#: 450-18113
HP Common Slot (CS) Power Supplies share a common electrical and physical design that allows for hot-swap, tool-less installation into HP server and storage solutions. HP's CS power supplies offer high-efficiency power options available in multiple input and output options, allowing users to "right-size" a power supply for specific server/storage configurations and environments. This flexibility helps to minimize power waste, lower overall energy costs, and avoid "trapped" power capacity in the data center
Dell - power supply - hot-plug - 495 Watt
Power supply - hot-plug
Power Capacity
495 Watt
PowerEdge R520 (495 Watt), R620 (495 Watt), R720 (495 Watt), R720xd (495 Watt), T320 (495 Watt), T420 (495 Watt), T620 (495 Watt); PowerVault DL2300, NX3200, NX3300
Power Capacity
495 Watt
Dell PowerEdge R520 (495 Watt), R620 (495 Watt), R720 (495 Watt), R720xd (495 Watt), T320 (495 Watt), T420 (495 Watt), T620 (495 Watt) , Dell PowerVault DL2300, NX3200, NX3300
