HPE HP PCIe x1 Parallel Port Card
Quicklinx: CFVMWS00 Mfr#: N1M40AA
£28.00 ex VAT
£33.60 inc VAT
Enable connectivity to your legacy peripheral devices with the HP Parallel Port PCIe x1 Card.
Adapt your current PC technology to accept your legacy environment by installing the card in any available PCIe slot on your PC. Then you’re ready to connect your parallel printers and devices.
  • Easy to install
    Adapt your current PC technology to accept your legacy environment by installing the card in any available PCIe slot on your PC. Then you're ready to connect your parallel printers and devices.
  • Supported by HP
    Protect your investment with a limited warranty.
HP - parallel adapter - PCIe
Parallel adapter
Interface (Bus) Type
PCI Express x1
HP 280, 280 G4, 280 G5, 285 G3, 285 G6, 290 G3, 290 G4, 295 G6, Z1 G8, Z1 G9; Desktop Pro 300 G6, Pro A 300 G3, Pro A G2, Pro A G3; Elite 600 G9, 800 G9; EliteDesk 705 G4, 800 G4, 80X G6, 80X G8; Pro 400 G9; ProDesk 400 G4, 400 G5, 405 G6; Workstation Z1 G5, Z1 G6, Z2 G4, Z2 G5, Z2 G8, Z2 G9, Z238
Parallel adapter
PCI Express x1
Wired
HP 280 G4, 280 G5, 280 Pro G5, 285 G3, 285 G6, 290 G3, 290 G4, 295 G6, Z1 G8, Z1 G9 , HP Desktop Pro 300 G6, Pro A 300 G3, Pro A G2, Pro A G3 , HP Elite 600 G9, 800 G9 , HP EliteDesk 705 G2 (micro tower, SFF), 705 G3, 705 G4, 800 G2, 800 G4, 800 G6, 800 G8, 805 G6, 805 G8 , HP EliteOne 800 G2 , HP Pro 400 G9 , HP ProDesk 400 G2.5 (SFF), 400 G4, 400 G5, 405 G6, 490 G3, 600 G2 (micro tower, SFF) , HP Workstation Z1 G5 Entry, Z1 G6 Entry, Z2 G4, Z2 G5, Z2 G8, Z2 G9, Z238
