HPE HP NC325M PCI Express Quad Port Gigabit Server Adapter
Quicklinx: 7R8JWS00 Mfr#: 416585-B21
The HP NC325m features four Gigabit Ethernet ports on a single card, saving valuable server I/O slots for other purposes. The four ports provide the highest port density available for ProLiant BladeSystem servers in a single adapter. The NC325m is ideal for virtualization, security, server consolidation, network segmentation, and other ProLiant server applications requiring maximum throughput and port density. The total aggregate throughput of four Gb/s meets the needs for customers desiring high bandwidth but are not yet ready to move to 10 Gigabit Ethernet.; The x4 PCI Express NC325m is supported on all ProLiant c-Class servers in all mezzanine slots. However, if the NC325m is installed in mezzanine slot 1 of a half-height server blade, it will provide connectivity on only two of the four ports.
  • Gigabit Ethernet Throughput
    The HP NC325m PCI Express Quad Port Gigabit Server Adapter supports four gigabit Ethernet ports on a single card, saving valuable server I/O slots for other purposes. The four ports provide the highest port density available for ProLiant BladeSystem servers in a single adapter.Offers up to 2000 Mbps Ethernet transfer rate full duplex per port and is ideal for high density, mezzanine slot constrained blade servers, virtualization and security, applications, server consolidation, and increased network segmentation.
HPE NC325M - network adapter - PCIe x4 - 4 ports
Network adapter
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.0
9.9 cm x 11.2 cm
Ports Qty
4 ports
GigE
Data Transfer Rate
1 Gbps
1 x Broadcom BCM5715S
RAM
312 KB
IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Standard Edition, Red Hat Enterprise Linux 3, SuSE Linux Enterprise Server 9 for x86/AMD64/Intel EM64T, Microsoft Windows Server 2003 Standard x64 Edition, Red Hat Enterprise Linux 4, Microsoft Windows Server 2003 Enterprise x64 Edition
ProLiant BL280c G6, BL2x220c G5, BL460c, BL460c G6, BL460c G7, BL465c, BL465c G6, BL465c G7, BL480c, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL620C G7, BL680c G7, BL685c, BL685c G6, BL685c G7; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3800sb G2
Network adapter - 4 ports
PCI Express x4
PCIe 1.0
Wired
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Network fault tolerance (NFT), transmit load balancing (TLB)
Processor / Memory
RAM
312 KB
4 x network
EN55022, EN55024, CISPR 22, EMC, IEC 60950-1, EN 60950-1
9.9 cm
11.2 cm
10 °C
35 °C
10 - 90%
HPE ProLiant BL280c G6, BL2x220c G5, BL460c, BL460c G6, BL460c G7, BL465c, BL465c G6, BL465c G7, BL480c, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL620C G7, BL680c G7, BL685c, BL685c G6, BL685c G7 , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3800sb G2
