Ideal for small businesses, the cost-effective HPE M210 802.11n Access Point Series, supports standalone operation or can be "clustered" for simplified administration of up to 4 access points where more robust coverage is required. These dual-band, single-radio devices support high-speed wireless networking at 5GHz or 2.4GHz to provide a better user experience and faster delivery of mobile applications. Clustering technology propagates wireless network configurations across all access points for consistent security and uninterrupted, wireless client roaming.
- HPE M210 (WW) - radio access point
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 4 , VLANs supported: 4
- Power Over Ethernet (PoE) Supported
- PoE
- 19.35 cm x 12.7 cm x 3.81 cm
- 340 g
- Limited lifetime warranty
- 19.35 cm
- 12.7 cm
- 3.81 cm
- 340 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- HTTP, HTTPS
- Communication Mode
- Half-duplex, full-duplex
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Auto-uplink (auto MDI/MDI-X), IPv6 support, Wireless Distribution System (WDS) support, MIMO technology, Spanning Tree Protocol (STP) support
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, SSL, TKIP, WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- IEC 60950-1 Second Edition, EN 300 328, EN 50385
- PoE
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 15 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.09 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.55 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.53 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £41.38 |
