Your basket is empty
HPE HP LTO6 Ultrium 2.5TB/6.25 TB Data Cartridge
Quicklinx: C44QWS00 Mfr#: C7976AN
Type: LTO Ultrium
Native Capacity: 2.5TB
£544.06 ex VAT
£652.87 inc VAT
With HPE Non-custom Labeled LTO Ultrium media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. Barcode sequences are unique to each batch ordered – no codes are repeated. HPE rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HPE Automation Group to evaluate and warrant the performance of its labels in demanding, split-second datacenter environments. These labels are professionally applied in a clean environment to ensuring 100% readability accurate storage. Non-Custom Labeled cartridges ensure 100% label readability and can be ordered online, in packs of 20, using a fast and simple process. For those customer who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the non-custom label and offers tracking, audit and security advantages for those with IT asset tracking systems.
HPE - LTO Ultrium x 20 - 2.5 TB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 6
Media Included Qty
20
Native Capacity
2.5 TB
Compressed Capacity
6.25 TB
Tape Length
846 m
Cartridge Labeling
Bar code labeled
30 years warranty
StorageWorks SAS Rack-Mount Kit; StoreEver MSL2024 Ultrium 6250, MSL4048 Ultrium 6250, MSL8096 Ultrium 6250; StoreEver 1/8 G2 Tape Autoloader Ultrium 6250
LTO Ultrium
Tape Cartridge
Ultrium 6
Media Included Qty
20
Cartridge Labeling
Bar code labeled
Media
Native Capacity
2.5 TB
Compressed Capacity
6.25 TB
Tape Length
846 m
30 years warranty
HPE StorageWorks SAS Rack-Mount Kit , HPE StoreEver MSL2024 Ultrium 6250, MSL4048 Ultrium 6250, MSL8096 Ultrium 6250 , HPE StoreEver 1/8 G2 Tape Autoloader Ultrium 6250
Type: LTO Ultrium
Brand: HPE
Price Range Ex VAT: 500 - 750
