Your basket is empty
HPE HP LTO-5 Ultrium 3 TB RW Eco Pack Custom Labelled Cart 20 pk
Quicklinx: 7DSVWS00 Mfr#: C7975AC
Type: LTO Ultrium
Native Capacity: 1.5TB
£439.45 ex VAT
£527.34 inc VAT
With HP Custom Labeled Media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. For no extra charge, cartridges can be supplied with barcode labels bearing your own specified sequences. HP rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HP Automation Group to evaluate and warrant the performance of its labels. These labels are professionally applied in a clean environment to ensure 100% readability accurate storage and retrieval in busy, automated tape libraries. Custom labeled cartridges ensure 100% label readability and can be ordered online in packs of 20. For those customers who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the customized label and offers tracking, audit and security advantages for those with IT asset tracking systems.
HPE Ultrium RW Custom Labeled No Case Data Cartridge - LTO Ultrium x 20 - 1.5 TB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 5
Media Included Qty
20
Light blue
Native Capacity
1.5 TB
Compressed Capacity
3 TB
Tape Length
846 m
Cartridge Labeling
Labeled
Metal Particle (MP)
HPE MSL2024 Ultrium 3000, MSL4048 Ultrium 3000, MSL8096 Ultrium 3000, MSL8096 Ultrium 3280; 1/8 G2 Tape Autoloader Ultrium 3000; LTO-5 Ultrium 3280; StoreEver MSL4048 LTO-5 Ultrium 3000, MSL6480 Scalable Base Module
LTO Ultrium
Tape Cartridge
Ultrium 5
Media Included Qty
20
Cartridge Labeling
Labeled
Light blue
Media
Native Capacity
1.5 TB
Compressed Capacity
3 TB
Tape Length
846 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
20 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE MSL2024 Ultrium 3000, MSL4048 Ultrium 3000, MSL8096 Ultrium 3000, MSL8096 Ultrium 3280 , HPE 1/8 G2 Tape Autoloader Ultrium 3000 , HPE LTO-5 Ultrium 3280 , HPE StoreEver MSL4048 LTO-5 Ultrium 3000, MSL6480 Scalable Base Module
7DSV HPE HP Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £88.83
Type: LTO Ultrium
Brand: HPE
Price Range Ex VAT: 300 - 500
