This high speed serial interface enables fast data transfer from external peripherals such as external hard disks, digital cameras and video cameras. Twice the transfer rate of IEEE-1394a cards, it features two external ports and one internal header. IEEE-1394b is one of the fastest serial interface standards ever developed which makes it great for use with high-speed or bandwidth-intensive multimedia peripherals such as digital video cameras, audio, streaming and graphics.
The HP IEEE-1394b FireWire 800 PCIe card is backward compatible to allow your IEEE-1394a devices to operate under the IEEE-1394b port with the use of a 1394a-to-1394b adapter cable.
The PCIe card features two external IEEE-1394b ports located on the PCIe card bracket and one internal port header located on the PCIe card to connect to front panel 1394a port on HP Workstations.
- HP - FireWire adapter - PCIe - 3 ports
- FireWire adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- Ports Qty
- 3 ports
- Data Link Protocol
- FireWire 800
- Data Transfer Rate
- 800 Mbps
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Vista
- Designed For
- Workstation xw9400, Z220, Z230, z400, Z420, z600, Z620, z800, Z820
- FireWire adapter - 3 ports
- Form Factor
- Plug-in card
- PCI Express
- Connectivity Technology
- Wired
- IEEE 1394b (FireWire 800)
- 800 Mbps
- 2 x FireWire 800 - 9 pin FireWire 800 (external) , 1 x FireWire 800 (internal)
- Compatible Slots
- 1 x PCI Express
- BSMI, FCC Part 15 B, MIC
- OS Required
- System Requirements Details
- Pentium III RAM 128 MB - HD 1 GB
- 10 °C
- 55 °C
- 20 - 80%
- Designed For
- HP Workstation xw9400, Z220, Z230, z400, Z420, z600, Z620, z800, Z820
