Your basket is empty
HPE HP IEEE 1394b FireWire PCIe Card
Quicklinx: BFF2WS00 Mfr#: NK653AA
Wired / Wireless: Wired
Protocol: IEEE 1394b (FireWire 800)
Form Factor: Plug-in card
Compatibility: PC
Type: FireWire adapter
This high speed serial interface enables fast data transfer from external peripherals such as external hard disks, digital cameras and video cameras. Twice the transfer rate of IEEE-1394a cards, it features two external ports and one internal header. IEEE-1394b is one of the fastest serial interface standards ever developed which makes it great for use with high-speed or bandwidth-intensive multimedia peripherals such as digital video cameras, audio, streaming and graphics.
The HP IEEE-1394b FireWire 800 PCIe card is backward compatible to allow your IEEE-1394a devices to operate under the IEEE-1394b port with the use of a 1394a-to-1394b adapter cable.
The PCIe card features two external IEEE-1394b ports located on the PCIe card bracket and one internal port header located on the PCIe card to connect to front panel 1394a port on HP Workstations.
HP - FireWire adapter - 3 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports Qty
3 ports
FireWire 800
Data Transfer Rate
800 Mbps
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Vista
Workstation xw9400, Z220, Z230, z400, Z420, z600, Z620, z800, Z820; Workstation z600
Plug-in card
PCI Express
Wired
FireWire 800
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800 (external) , 1 x FireWire 800 (internal)
Compatible Slots
1 x PCI Express
BSMI, FCC Part 15 B, MIC
System Requirements Details
Pentium III RAM 128 MB - HD 1 GB
10 °C
55 °C
20 - 80%
HP Workstation xw9400, Z220, Z230, z400, Z420, z600, Z620, z800, Z820 , HPE Workstation z600
Compatibility: PC
Brand: HPE
Price Range Ex VAT: 50 - 100
