Product
HPE HP HP Ethernet 10Gb 2-port 530FLR-SFP+ Adapter
Quicklinx: 8FVJWS00 Mfr#: 647581-B21
Do you need a 10GbE NIC with advanced features for HPE ProLiant servers? The HPE Ethernet 10Gb 2-port 530FLR-SFP+ adapter features the single chip 10GbE solution from Logic in a FlexibleLOM form factor designed for select HPE ProLiant Gen8 rack servers. The HPE 530FLR dual-port design with a total aggregate throughput of 20 Gb meets the needs for customers desiring high bandwidth. The HPE 530FLR supports enterprise class features such as VLAN tagging, adaptive interrupt coalescing, MSI-X, NIC teaming (bonding), Receive Side Scaling (RSS), jumbo frames, PXE boot and virtualization features such as VMware NetQueue and Microsoft VMQ. The adapter's support for HPE Sea of Sensors 3D Technology enhances server performance by reducing energy consumption and expense.
  • Single-chip, Dual-port 10 Gb Ethernet FlexibleLOM Designed for Select HPE ProLiant Gen8 Rack Servers
    20Gb/s full duplex Ethernet transfer rate per port (40 Gb/s aggregate) provides the network performance needed to improve response times and alleviate bottlenecks for the most demanding workloads in next generation data centers.Comprehensive stateless offloads optimize host efficiency and VM density by leaving host CPU available for other duties.Virtualization support for VMware NetQueue and Microsoft VMQ meet the performance demands of consolidated virtual workloads.Support for MSI/MSI-X provides performance benefits for multi-core servers by load balancing interrupts between CPUs/cores.Stateful hardware offload for TCP/IP: TCP Offload Engine (TOE).
  • Other Key Features
    Dual-port 10 Gb Ethernet SFP+ Flexible LOM adapter.Up to 40 Gb/s bi-directional near line rate throughput.Single-chip solution integrating PHY and MAC.
HPE 530FLR-SFP+ - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports
10Gb Ethernet x 2
10 GigE
Data Transfer Rate
10 Gbps
1 x BCM57810S - Broadcom
RAM
256 MB
IEEE 802.3, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3p, IEEE 802.3ap, IEEE 802.1au
SunSoft Solaris 10, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows HPC Server 2008, Red Hat Enterprise Linux 6, Red Hat Enterprise Linux 5.x
ProLiant DL160 Gen8, DL360p Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8
Network adapter
Plug-in card
PCI Express 2.0 x8
PCIe 2.0
Ports
10Gb Ethernet x 2
Wired
10 GigE
Data Transfer Rate
10 Gbps
Remote Management Protocol
SNMP
Status Indicators
Port status, link/activity
Jumbo Frames support, teaming support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS)
Processor / Memory
RAM
256 MB
2 x 10Gb Ethernet
Compatible Slots
1 x FlexibleLOM
VCCI Class B ITE, EN 61000-3-2, EN55022, EN 61000-3-3, FCC Part 15 B, WEEE, RoHS
55 °C
10 - 90% (non-condensing)
HPE ProLiant DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray
8FVJ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
8FVJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
8FVJ C2G 2m Cat6a Shielded Patch - Blue In Stock £6.98
