Your basket is empty
HPE HP HP BLC VC 1GB RJ-45 SFP Option Kit
Quicklinx: 7NT2WS00 Mfr#: 453154-B21
Type: Modules
Hurry, only 3 left in stock!
£182.55 ex VAT
£219.06 inc VAT
The HP BladeSystem c-Class SFP Transceivers provide high performance Ethernet connectivity and bring customers more choices for using either copper or optical cables.
HPE - SFP (mini-GBIC) transceiver module - Ethernet, Fast Ethernet, Gigabit Ethernet
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
HP 1/10Gb-F Virtual Connect Ethernet Module, 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem; HPE 6120G/XG Blade Switch, 6120XG Blade Switch; BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; Virtual Connect Flex-10
Plug-in module
Wired
Cabling Type
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-T
Compatible Slots
1 x SFP (mini-GBIC)
HP 1/10Gb-F Virtual Connect Ethernet Module, 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem , HPE 6120G/XG Blade Switch, 6120XG Blade Switch , HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE Virtual Connect Flex-10
Type: Modules
Brand: HPE
Price Range Ex VAT: 150 - 300
