HPE OfficeConnect 1405-5 Switch V2
Quicklinx: 8JVKWS00 Mfr#: J9791A
The HPE 1405 Switch Series is a plug-and-play unmanaged fixed-port Layer 2 switch designed for small offices. These switches are preconfigured with connections using low-cost Ethernet copper cabling. They are Class B certified, energy efficient and quiet. They support administration-friendly features such as auto-negotiation. Designed for high reliability, long life, and low power consumption, they are ideal for businesses concerned with total cost of ownership.
  • Ease of Use
    The HPE OfficeConnect 1405 Switch Series offers unmanaged plug-and-play simplicity.A comprehensive LED display with per-port indicators provides an at-a-glance view of status, activity, speed, and full duplex operation.Flow control helps to provide reliable communications during full-duplex operation.
  • Connectivity and Performance
    The HPE OfficeConnect 1405 Switch Series with Auto-MDIX automatically adjusts to straight-through or crossover cables on all 10/100 and 10/100/1000 ports.Jumbo packet support for Gigabit Ethernet ports only offers up to 9216-byte frame size to improve performance of larger data transfers.Half/Full duplex auto-negotiating capability on every port doubles the throughput of every port.
  • Quality of Service (QoS)
    The HPE OfficeConnect 1405 Switch Series has IEEE 802.1p prioritization delivering data to devices based on priority and type of traffic.The switches support energy efficient Ethernet.
HPE 1405-5 v2 Switch - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
Throughput: up to 0.7 Mpps
MAC Address Table Size
2K entries
Jumbo Frame Support
9216 bytes
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Jumbo Frames support, fanless, Mini Jumbo Frame support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
11.43 cm x 9.14 cm x 3.56 cm
180 g
3-year warranty
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
2K entries
Jumbo Frame Support
9216 bytes
RAM
384 KB
Status Indicators
Port status, port transmission speed, link/activity
5 x 100Base-TX RJ-45
External power adapter
CISPR 22 Class B, UL 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15, IEC 60950-1, EN 60950-1, CAN/CSA-C22.2 No. 60065-03
11.43 cm
9.14 cm
3.56 cm
180 g
Limited warranty - advance parts replacement - 3 years , Technical support - phone consulting - 3 years
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
8JVK C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
