The HPE 1405 Switch Series is a plug-and-play unmanaged fixed-port Layer 2 switch designed for small offices. These switches are preconfigured with connections using low-cost Ethernet copper cabling. They are Class B certified, energy efficient and quiet. They support administration-friendly features such as auto-negotiation. Designed for high reliability, long life, and low power consumption, they are ideal for businesses concerned with total cost of ownership.
Ease of Use
The HPE OfficeConnect 1405 Switch Series offers unmanaged plug-and-play simplicity.A comprehensive LED display with per-port indicators provides an at-a-glance view of status, activity, speed, and full duplex operation.Flow control helps to provide reliable communications during full-duplex operation. -
Connectivity and Performance
The HPE OfficeConnect 1405 Switch Series with Auto-MDIX automatically adjusts to straight-through or crossover cables on all 10/100 and 10/100/1000 ports.Jumbo packet support for Gigabit Ethernet ports only offers up to 9216-byte frame size to improve performance of larger data transfers.Half/Full duplex auto-negotiating capability on every port doubles the throughput of every port. -
Quality of Service (QoS)
The HPE OfficeConnect 1405 Switch Series has IEEE 802.1p prioritization delivering data to devices based on priority and type of traffic.The switches support energy efficient Ethernet.
- HPE 1405-5 v2 Switch - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Performance
- Throughput: up to 0.7 Mpps
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, Jumbo Frames support, fanless, Mini Jumbo Frame support, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 11.43 cm x 9.14 cm x 3.56 cm
- 180 g
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Performance
- 2K entries
- 9216 bytes
- RAM
- 384 KB
- Status Indicators
- Port status, port transmission speed, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- Voltage Required
- CISPR 22 Class B, UL 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15, IEC 60950-1, EN 60950-1, CAN/CSA-C22.2 No. 60065-03
- 11.43 cm
- 9.14 cm
- 3.56 cm
- 180 g
- Limited warranty - advance parts replacement - 3 years , Technical support - phone consulting - 3 years
- 0 °C
- 40 °C
- 15 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
