Your basket is empty
HPE HP FlexFabric 10Gb 2-port 554FLR-SFP+ Adapter
Quicklinx: 80LRWS00 Mfr#: 629142-B21
The HP FlexFabric 10Gb 2-port 554FLR-SFP+ Adapter provides Ethernet functionality or Ethernet and iSCSI or Fibre Channel Over Ethernet (FCoE) or FlexFabric connectivity in a FlexibleLOM form factor designed for select HP ProLiant Gen8 rack servers. It reduces operating costs by reducing the number of adapters and cables needed. It also optimizes network and storage traffic with hardware acceleration and offloads for stateless TCP/IP, TCP Offload Engine (TOE), and Fibre Channel.
HPE FlexFabric 554FLR-SFP+ - network adapter - 2 ports
Network adapter
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports Qty
2 ports
10 GigE
Data Transfer Rate
10 Gbps
1 Emulex
RAM
128 MB
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3ap, IEEE 802.3az, IEEE 802.1Qau
SunSoft Solaris 10, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 R2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2008, Microsoft Windows HPC Server 2008, Red Hat Enterprise Linux 6, Red Hat Enterprise Linux 5.x, VMware ESX 4.1, VMware ESX 4.0
ProLiant DL360p Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8
Network adapter - 2 ports
PCI Express 2.0 x8
PCIe 2.0
Wired
10 GigE
Data Transfer Rate
10 Gbps
Auto-negotiation, wake on LAN (WOL), Jumbo Frames support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS)
Processor / Memory
1 Emulex
RAM
128 MB
Compatible Slots
1 x FlexibleLOM
FCC Class A certified, UL, CISPR 22 Class A, EN 60950, VCCI Class A ITE, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, MIC Class A, ACA, ACPI 1.1, BSMI Class A
55 °C
10 - 90% (non-condensing)
HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray
80LR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
80LR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
80LR C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
80LR C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
