The HP Ethernet 1Gb 4-port 331FLR Adapter for select HP ProLiant Gen8 and Gen9 rack servers features the next generation of Ethernet integration, offering a single-chip solution in a FlexibleLOM form factor, which offers the option for future upgrades to 10GbE networking speeds. It delivers full line-rate performance across all ports with low power consumption. The HP 331FLR is ideal for virtualization, security, server consolidation, network segmentation, and other applications requiring maximum throughput and port density. The total aggregate throughput of 4Gb meets the needs of customers desiring high bandwidth. The HP 331FLR supports advanced features such as Large Send and Receive offload capability, TCP checksum and segmentation, VLAN tagging, MSI-X, jumbo frames, IEEE 1588, HP Sea of Sensors 3D and virtualization features such as VMware NetQueue and Microsoft VMQ. Support for HP Sea of Sensors 3D Technology enhances server performance while reducing energy use and expense.
- HPE 331FLR - network adapter - 4 ports
- Network adapter
- Interface (Bus) Type
- PCI Express 2.0 x4
- 11.8 cm x 7.6 cm
- Ports Qty
- 4 ports
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- Processor
- 1 Broadcom
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
- Designed For
- ProLiant DL360p Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8
- Network adapter - 4 ports
- Connectivity Technology
- Wired
- 1 Gbps
- Status Indicators
- Port transmission speed, link/activity
- Jumbo Frames support, PXE support, Large Send Offload (LSO)
Processor / Memory
- Processor
- 1 Broadcom
- 4 x network - RJ-45
- UL, VCCI Class B ITE, EN55022 Class B, FCC Part 15 B, RoHS, ICES
- 11.8 cm
- 7.6 cm
- 0 °C
- 55 °C
- 10 - 90% (non-condensing)
- Designed For
- HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.09 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.60 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.53 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £41.38 |
