Brand
HPE HP Ethernet 1Gb 4-port 331T Adapter
Quicklinx: 8JLNWS00 Mfr#: 647594-B21
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
More than 50 in stock
£122.19 ex VAT
£146.62 inc VAT
The HP Ethernet 1Gb 4-Port 331T Adapter features the next generation of Ethernet integration, offering a single chip solution that reduces power requirements and optimizes I/O slot utilization. It delivers full line-rate performance across all ports with low power consumption. The HP 331T is ideal for virtualization, security, server consolidation, network segmentation, and other applications requiring maximum throughput and port density. The total aggregate throughput of 8Gb meets the needs of customers desiring high bandwidth. The HP 331T supports advanced features such as Large Send and Receive offload capability, TCP checksum and segmentation, VLAN tagging, MSI-X, jumbo frames, IEEE 1588, and virtualization features such as VMware NetQueue and Microsoft VMQ. Support for HP Sea of Sensors 3D Technology enhances server performance while reducing energy use and expense.
  • The HPE 331T is Designed for Maximum Throughput and High Port Density
    An aggregate, full duplex transfer rate of 8 Gb/s per adapter delivers outstanding network performance that improves response time and removes bottlenecks.Comprehensive stateless offloads optimize host efficiency and VM density by leaving host CPU available for other duties.Virtualization support for VMware NetQueue and Microsoft VMQ help meet the performance demands of consolidated virtual workloads.Support for MSI/MSI-X provides performance benefits for multi-core servers by load balancing interrupts between CPUs/cores.Support for Energy Efficient Ethernet (EEE) reduces operating expenses.
HPE 331T - network adapter - PCIe 2.0 x4 - Gigabit Ethernet x 4
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x4
PCI Specification Revision
PCIe 2.0
Ports
13.2 cm x 6.9 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1 x Broadcom BCM5719
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL360 Gen10, DL380 Gen10, DL388p Gen8, DL560 Gen10, MicroServer Gen10, XL170r Gen10, XL190r Gen10; SimpliVity 380 Gen10
Network adapter
PCI Express 2.0 x4
PCIe 2.0
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, link/activity
Jumbo Frames support, PXE support, Large Send Offload (LSO)
Processor / Memory
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express 2.0 x4
Low-profile bracket, full-height bracket
VCCI Class B ITE, EN 61000-3-2, EN55022, EN 61000-3-3, FCC Part 15 B, WEEE, RoHS
13.2 cm
6.9 cm
55 °C
10 - 90% (non-condensing)
HPE Apollo 4200 Gen10, 4200 Gen9 for Google , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10 , HPE ProLiant DL120 Gen10, DL180 Gen10, DL180 Gen10 Entry, DL180 Gen10 SMB, DL20 Gen9 Solution, DL325 Gen10 Base, DL325 Gen10 Solution, DL360 Gen10 All Flash Server for Weka, DL360 Gen10 Compute Server for Cohesity DataPlatform, DL360 Gen10 Low, DL360 Gen10 Network Choice, DL360 Gen10 Performance for Cohesity DataPlatform, DL360 Gen10 SMB, DL360 Gen10 SMB Network Choice, DL360 Gen10 Solution, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL388 Gen10 Network Choice, DL388p Gen8 Base, DL560 Gen10 for SAP HANA Compute Block, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, MicroServer Gen10, MicroServer Gen10 Solution, MicroServer Gen10 Stockage Collaboration, ML110 Gen10, ML110 Gen10 Solution, ML30 Gen10, ML30 Gen10 Entry, ML30 Gen10 Performance, ML30 Gen10 Solution, ML30 Gen9 Entry, ML30 Gen9 Solution, ML350 Gen10 Base, ML350 Gen10 Entry, ML350 Gen10 High Performance, ML350 Gen10 Performance, ML350 Gen10 SMB, ML350 Gen10 Solution, ML350 Gen10 Sub-Entry, XL170r Gen10, XL170r Gen10 24TB Server for Cohesity DataPlatform, XL170r Gen10 36TB Add-on Server for Cohesity DataPlatform, XL190r Gen10, XL190r Gen10 for HPE Ezmeral Container Platform, XL450 Gen10 , HPE SimpliVity 325 Gen10 Node, 380 Gen10 G Node, 380 Gen10 H Node, 380 Gen10 Network Choice G Node, 380 Gen10 Network Choice H Node, 380 Gen10 Node , HPE StoreEasy 1660 Expanded Storage
8JLN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.22
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: HPE
Stock Status: In stock
