Your basket is empty
HPE HP 8GB DDR3L SO DIMM 204-pin 1600 MHz/PC3-12800 1.35 V unbuffered non-ECC Memory Module
Quicklinx: B17PWS00 Mfr#: H6Y77ET#AC3
Type: DDR3L SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Registered/Buffered: Unbuffered
£53.14 ex VAT
£63.76 inc VAT
Optimize your HP Business Notebook performance and realize energy savings with the new low-power HP 8 GB DDR3L 1600 MHz 1.35V SODIMM memory.
HP - DDR3L - 8 GB - SO-DIMM 204-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Voltage
1.35 V
HP 250 G5; EliteBook 2760, 725 G2, 745 G2, 745 G3, 755 G2, 755 G3, 820 G1, 820 G2, 840 G1, 840 G2, 850 G1, 850 G2, 87XX; EliteBook Folio 1020 G1, 9470; EliteBook Revolve 810 G1; ProBook 430 G1, 430 G3, 440 G3, 450 G0, 45X G1, 45X G3, 470 G0, 470 G1, 470 G3, 64X G1, 65X G1; x360; ZBook 15, 15u G2, 17
8 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Voltage
1.35 V
HP 250 G5 , HP EliteBook 2170p, 2560p, 2760p, 725 G2, 745 G2, 745 G3, 755 G2, 755 G3, 820 G1, 820 G2, 840 G1, 840 G2, 8460p, 8460w, 8470p, 8470w, 850 G1, 850 G2, 8560p, 8560w, 8570p, 8570w, 8760w, 8770w , HP EliteBook Folio 1020 G1, 9470m , HP EliteBook Revolve 810 G1 Tablet , HP Envy Pro , HP Mobile Thin Client 6360t , HP ProBook 430 G1, 430 G3, 440 G3, 450 G0, 450 G1, 450 G3, 455 G1, 455 G3, 470 G0, 470 G1, 470 G3, 6360b, 640 G1, 645 G1, 6460b, 6465b, 6470b, 6475b, 650 G1, 655 G1, 6560b, 6565b, 6570b , HP x360 310 G1 , HP ZBook 15 Mobile Workstation, 15u G2 Mobile Workstation, 17 Mobile Workstation
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 1600MHz
Brand: HPE
Price Range Ex VAT: 50 - 100
