Looking to reduce energy cost and space with increased performance? HP Common Slot Power Supplies share a common electrical and physical design that allows for hot-swap, tool-less installation into HP server and storage solutions. These power supplies are available in multiple, high-efficiency input and output options, allowing you to "right-size" a power supply for specific server/storage configurations and environments. This flexibility helps to reduce power waste, lower overall energy costs, and avoid "trapped" power capacity in the data center. The power supplies provide the IT industry's highest level of power efficiency (up to 96%), helping users to reduce power requirements per server and reducing overall data center power requirements. The Platinum Plus and Titanium power supplies also enable HP Power Discovery Services which focus on increasing compute density while reducing data center outages.
Best in Class Power Supply Technology
HP Common Slot Power Supplies are designed to simplify the serviceability and maintenance of power supplies across the HP portfolio of server and storage products by being hot-swappable and providing a tool-less installation.Multiple power management options deliver greater power efficiency when using redundant power supplies to reduce overall power usage.Multiple input and output options deliver increased flexibility in usage while reducing the chances of creating "trapped" power capacity in the data center.HP Common Slot Power Supplies have Titanium level certification by both the 80Plus program and the EPRI providing the highest level of power efficiency (up to 96%) in the IT industry.Higher-end power supplies offer HP Power Discovery Services that help customers reduce human error during the installation process, reclaim over-provisioned power capacity in the data center, and accurately measure/monitor power usage.
- HPE Common Slot Platinum Plus Power Supply Kit - power supply - hot-plug - 750 Watt
- Power supply - hot-plug - plug-in module
- 80 PLUS Certification
- 80 PLUS Platinum
- Input Voltage
- AC 100-240 V
- Power Capacity
- 750 Watt
- Designed For
- ProLiant DL160 Gen8, DL360e Gen8, DL360p Gen8, DL380p Gen8, DL385p Gen8, DL388p Gen8, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL4540 Gen8, SL4545 G7
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Power Capacity
- 750 Watt
- 80 PLUS Platinum
- Designed For
- HPE ProLiant DL160 Gen8 (750 Watt), DL160 Gen8 Base (750 Watt), DL160 Gen8 Entry (750 Watt), DL160 Gen8 Performance (750 Watt), DL360e Gen8 (750 Watt), DL360e Gen8 Entry (750 Watt), DL360e Gen8 Performance (750 Watt), DL360e Gen8 Special Server (750 Watt), DL360p Gen8 (750 Watt), DL360p Gen8 Base (750 Watt), DL360p Gen8 CMS (750 Watt), DL360p Gen8 Entry (750 Watt), DL360p Gen8 High Performance (750 Watt), DL380p Gen8 (750 Watt), DL380p Gen8 Base (750 Watt), DL380p Gen8 Entry (750 Watt), DL380p Gen8 High Performance (750 Watt), DL380p Gen8 Special (750 Watt), DL385p Gen8 (750 Watt), DL385p Gen8 Dedicated Workload (750 Watt), DL385p Gen8 Entry (750 Watt), DL385p Gen8 Maximized Consolidation (750 Watt), DL385p Gen8 Storage (750 Watt), DL388p Gen8 Base (750 Watt), ML350e Gen8 (750 Watt), ML350e Gen8 Base (750 Watt), ML350e Gen8 Entry (750 Watt), ML350e Gen8 Performance (750 Watt), ML350e Gen8 v2 (750 Watt), ML350e Gen8 v2 Base (750 Watt), ML350p Gen8 (750 Watt), ML350p Gen8 Base (750 Watt), ML350p Gen8 Entry (750 Watt), ML350p Gen8 Performance (750 Watt), ML350p Gen8 Special Server (750 Watt), SL210t Gen8 1U Node (750 Watt), SL230s Gen8 1U Left Half Width Tray (750 Watt), SL230s Gen8 1U Right Half Width Tray (750 Watt), SL230s Gen8 Base 1U Left Tray Server (750 Watt), SL230s Gen8 Base 1U Right Tray Server (750 Watt), SL250s Gen8 2U Left Half Width Tray (750 Watt), SL250s Gen8 2U PCIe Gen3 Left Tray (750 Watt), SL250s Gen8 2U PCIe Gen3 Right Tray (750 Watt), SL250s Gen8 2U Right Half Width Tray (750 Watt), SL250s Gen8 Base 2U Left Half Width Tray (750 Watt), SL250s Gen8 Base 2U Left Tray Server (750 Watt), SL250s Gen8 Base 2U Right Half Width Tray (750 Watt), SL250s Gen8 Base 2U Right Tray Server (750 Watt), SL4540 Gen8 (750 Watt), SL4540 Gen8 Tray 1x Node Server, SL4540 Gen8 Tray 2x Node Server (750 Watt), SL4540 Gen8 Tray 3x Node Server, SL4545 G7
