Do you need an Enterprise-class rack solution that helps you fine-tune resources and achieve more compute power in limited space? HP Enterprise Series Racks, in a wide range of sizes, offer innovative intelligence capabilities for asset management, unparalleled structural integrity, cooling and cable management, and a wide choice of power and switching options customizable to match your compute requirements today and in the future. When paired with optional HP Location Discovery Services, the rack identification number and precise U location is sent to the servers providing important location information to iLO, HP OneView and Insight Control Software allowing you to place workloads more efficiently. Manual, error-prone asset management is removed because servers can now self-identify and inventory themselves. For those that require greater load capacity, choose an Enterprise Series Rack that can be fully configured and shipped to your site.
Reclaim Limited Space, Power, and Cooling Resources
Up to 3000 pounds of dynamic loading enables HPE Enterprise Series Racks to ship and be moved fully configured with all types of equipment so.An innovative 81% open perforation area on the door helps better cool servers.Cable management in the back of the rack provides tool-less operations and extra space for hot air to pass from the rack. -
Designed for the Data Center
HPE Enterprise Series Racks offer a range of heights in both 600mm and 800mm widths available.Universal rack design compatible with all HPE rack mount products including servers, networking, and storage.Full line of options and accessories to create the rack that supports your compute solution needs.Optional HPE Location Discovery Services allow you to fine-tune workload placement with servers that self-identify and inventory themselves, allowing you to efficiently place workloads while removing manual, error prone asset management tasks. -
The Hewlett Packard Enterprise Advantage
HPE Enterprise Series Racks are designed for and tested to perform with HPE Server and Networking technology solutions.HPE Foundation Care services purchased for servers and storage extend to our rack and power infrastructure products. What is the HPE advantage for you? Save $$$.HPE exclusive tools help maintain and manage all equipment in the rack.Hewlett Packard Enterprise offers an extensive range of rack, power, and KVM products to meet all your needs.Hewlett Packard Enterprise can help to simplify IT purchasing, installation, usage, and maintenance.
- HPE 600mm x 1075mm Enterprise Pallet Rack - rack - 36U
- Product Type
- Rack
- Black frame, black with silver extrusion
- Height (Rack Units)
- 36U
- 59.7 cm x 112.51 cm x 174.86 cm
- 97 kg
- 3-year warranty
- Designed For
- ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, DL60 Gen9, DL80 Gen9, ML310e Gen8, ML350 Gen9, ML350e Gen8, ML350p Gen8
- Product Type
- Rack
- 36U
- 59.7 cm
- 112.51 cm
- 174.86 cm
- 97 kg
- Weight Limit
- 1360 kg
- Limited warranty: parts - 3 years
- Designed For
- HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 Special Server, DL320e Gen8 v2, DL320e Gen8 v2 Base, DL320e Gen8 v2 Entry, DL320e Gen8 v2 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance
