Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
Performance and Reliability for Multiple Application Environments
HPE Server SAS Hard Drives deliver high reliability for mission-critical applications.Robust SAS interface (dual port, full duplex) for increased performance.HPE Smart Carrier for HPE ProLiant Servers (both Gen8 and Gen9 are supported). They maintain backward compatibility with existing standard hot-plug carriers to provide support for HPE ProLiant G7 and earlier servers and server storage enclosures.They are ideal for transaction processing, database applications, analytics, high-performance computing and business applications.The 512e Advance Format Drive is ideal for 4KiB aligned operating systems and applications. They also support legacy 512K native applications.
- HPE Dual Port Enterprise - hard drive - 600 GB - SAS 6Gb/s
- Hard drive - hot-swap
- Capacity
- 600 GB
- Form Factor
- 2.5" SFF
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 10000 rpm
- 7.9 cm x 13.8 cm x 1.6 cm
- 3-year warranty
- Designed For
- Integrity BL860c, BL860c i2, BL860c i4, BL870c i2, BL890c i2; ProLiant BL460c G6, BL460c G7, BL465c G6, BL465c G7, BL620C G7, BL680c G7, BL685c G6, BL685c G7, DL120 G7, DL160 G6, DL160se G6, DL165 G7, DL180 G6, DL320 G6, DL360 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G7, DL585 G6, DL585 G7, DL785 G6, DL980 G7, ML350 G6, ML370 G6, WS460c G6
- Capacity
- 600 GB
- Form Factor
- 2.5" SFF
- Interface
- SAS 6Gb/s
- Bytes per Sector
- 512
- 7.9 cm
- 13.8 cm
- 1.6 cm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Seek Time
- 4 ms (average) / 8 ms (max)
- Track-to-Track Seek Time
- 0.4 ms
- Spindle Speed
- 10000 rpm
Expansion & Connectivity
- 1 x SAS 6Gb/s
- Compatible Bay
- 2.5" SFF
- Limited warranty - 3 years
- 10 °C
- 35 °C
- Designed For
- HPE Integrity BL860c i2 (2.5"), BL860c i2 Base (2.5"), BL860c i4 (2.5"), BL870c i2 (2.5"), BL890c i2 (2.5"), BL890c i2 Base (2.5") , HPE ProLiant BL460c G6 (2.5"), BL460c G7 (2.5"), BL465c G6 (2.5"), BL465c G7 (2.5"), BL620C G7 (2.5"), BL680c G7 (2.5"), BL685c G6 (2.5"), BL685c G7 (2.5"), DL120 G7 (2.5"), DL160 G6 (2.5"), DL160 G6 Special Server (2.5"), DL160se G6 (2.5"), DL165 G7 (2.5"), DL165 G7 Performance (2.5"), DL165 G7 Special Server (2.5"), DL180 G6 (2.5"), DL180 G6 Special Server (2.5"), DL320 G6 (2.5"), DL360 G6 (2.5"), DL360 G6 Base (2.5"), DL360 G6 Efficiency (2.5"), DL360 G6 Entry (2.5"), DL360 G6 Performance (2.5"), DL360 G7 (2.5"), DL360 G7 Base (2.5"), DL360 G7 Central Management Server (2.5"), DL360 G7 Efficiency (2.5"), DL360 G7 Entry (2.5"), DL360 G7 Performance (2.5"), DL360 G7 Special Server (2.5"), DL370 G6 (2.5"), DL370 G6 Base (2.5"), DL370 G6 High Performance (2.5"), DL370 G6 Performance (2.5"), DL370 G6 Special Server (2.5"), DL380 G6 (2.5"), DL380 G6 Base (2.5"), DL380 G6 Entry (2.5"), DL380 G6 High Efficiency (2.5"), DL380 G6 Performance (2.5"), DL380 G7 (2.5"), DL380 G7 Base (2.5"), DL380 G7 Efficiency (2.5"), DL380 G7 Entry (2.5"), DL380 G7 Performance (2.5"), DL380 G7 Special Server (2.5"), DL385 G6 (2.5"), DL385 G6 Base (2.5"), DL385 G6 Entry (2.5"), DL385 G6 High Performance (2.5"), DL385 G6 ICE Performance (2.5"), DL385 G7 (2.5"), DL385 G7 Base (2.5"), DL385 G7 Entry (2.5"), DL385 G7 HE (2.5"), DL385 G7 Performance (2.5"), DL580 G7 (2.5"), DL580 G7 Base (2.5"), DL580 G7 High Performance (2.5"), DL585 G6 (2.5"), DL585 G6 Base (2.5"), DL585 G6 Performance (2.5"), DL585 G7 (2.5"), DL585 G7 Base (2.5"), DL585 G7 Performance (2.5"), DL785 G6 (2.5"), DL785 G6 Base (2.5"), DL785 G6 Performance (2.5"), DL980 G7 (2.5"), ML350 G6 Base (2.5"), ML350 G6 Performance (2.5"), ML350 G6 Special Server (2.5"), ML370 G6 (2.5"), ML370 G6 Base (2.5"), ML370 G6 Entry (2.5"), WS460c G6 Workstation (2.5")
