Product
HPE HP 561T Network Adapter
Quicklinx: 98HYWS00 Mfr#: 716591-B21
The HP Ethernet 10GbE dual port 561T adapter features the latest generation 10 GbE Intel Ethernet Controller X540. The HP 561T is a low cost, low power dual port 10GBASE-T adapter designed for use in HP ProLiant Gen8 rack, tower, and scalable servers. The HP 561T addresses the demanding needs of the next-generation data center by providing unmatched features for virtualization, and scalability to keep up with the HP ProLiant Gen8 server platform, with proven and reliable performance HP customers have come to expect. The HP 561T adapter enables connections with standard CAT6 or better UTP cabling. The HP 561T supports high performance networking features such as VLAN tagging, Low latency interrupts, TCP and UDP checksum offloading, MSI-X, NIC teaming (bonding), Receive Side Scaling (RSS), jumbo frames, PXE boot and virtualization features which are VMDq and SR-IOV ready.
  • Dual-port 10Gb Ethernet 10GBASE-T Standup Adapter Designed for Maximum Network Performance
    20Gbps full duplex Ethernet transfer rate per port.Intel Virtualization Technology for Connectivity (VT-c) with VMDq and SR-IOV supports VMware NetQueue and Microsoft VMQ helping to meet the performance demands of consolidated virtual workloads.Supports PXE, MSI-X support, Teaming, and IPv6.Adapter supports HPE Sea of Sensors 3D Technology.New Intel Data Direct I/O technologies reduces system power, increases I/O performance and reduces I/O latency.
HPE 561T - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.1 x8
Ports
10Gb Ethernet x 2
10 GigE
Data Transfer Rate
10 Gbps
1 x x540 - Intel
IEEE 802.3, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau
SunSoft Solaris 10, Microsoft Windows Server 2008 Foundation, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008 Enterprise, Microsoft Windows Server 2008 Standard, Microsoft Windows Web Server 2008, Microsoft Windows Server 2008 Datacenter, Red Hat Enterprise Linux 6, Microsoft Windows Small Business Server 2011 Standard, Microsoft Windows Small Business Server 2011 Essentials, Microsoft Windows MultiPoint Server 2011, Citrix XenServer 6.0, Microsoft Windows Server 2012, SunSoft Solaris 11, Citrix XenServer 6.1, VMware vSphere 5.0, VMware vSphere 4.1
Apollo pc40, sx40; ProLiant DL180 Gen9, DL20 Gen9, DL360p Gen8, DL380 Gen9, DL380p Gen8, DL385p Gen8, DL560 Gen9, DL80 Gen9, ML110 Gen9, ML30 Gen9, ML350 Gen9, ML350e Gen8, ML350p Gen8, SL270s Gen8, SL4540 Gen8, SL4545 G7, XL170r Gen9, XL190r Gen9; SimpliVity 380 Gen9; StoreEasy 1450, 1850, 3850
Network adapter
Plug-in card
PCI Express 2.1 x8
Ports
10Gb Ethernet x 2
Wired
10 GigE
Data Transfer Rate
10 Gbps
Remote Management Protocol
SNMP
Status Indicators
Port status, link/activity
Jumbo Frames support, teaming support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS), TCP Segmentation Offload (TSO)
Processor / Memory
1 x x540 - Intel
2 x 10Gb Ethernet - RJ-45
UL, BSMI, BSMI CNS 13438 Class A, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, WEEE, FCC Part 15 A, VCCI V-3 Class A ITE
55 °C
5 - 95% (non-condensing)
HPE Apollo pc40, sx40 , HPE ProLiant DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380 Gen9 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Entry, ML30 Gen9 Performance, ML30 Gen9 Solution, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350p Gen8, ML350p Gen8 Special Server, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, SL4540 Gen8, SL4540 Gen8 Tray 2x Node Server, SL4545 G7, XL170r Gen9, XL190r Gen9 , HPE SimpliVity 380 Gen9 Node , HPE StoreEasy 1450, 1850, 3850 Gateway Single Node
98HY C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
98HY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
98HY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
98HY C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.82
