Your basket is empty
HPE HP 4GB 1Rx8 PC4-2133P-R Kit
Quicklinx: BMNMWS00 Mfr#: 726717-B21
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2133MHz
Registered/Buffered: Registered
Hurry, only 1 left in stock!
£74.26 ex VAT
£89.11 inc VAT
Maximize your PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
HPE - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Single rank, registered
Voltage
1.2 V
HP 726717-B21
Apollo 4530; ProLiant DL180 Gen9, DL360 Gen9, DL380 Gen9, DL80 Gen9, ML110 Gen9, ML350 Gen9, XL170r Gen9, XL190r Gen9
4 GB
Upgrade Type
System specific
HP 726717-B21
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X8
Voltage
1.2 V
HPE Apollo 4530 , HPE ProLiant DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance, DL80 Gen9, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML350 Gen9, XL170r Gen9, XL190r Gen9
HPE HP 4GB 1Rx8 PC4-2133P-R Kit Bundle deal on HPE HP 4GB 1Rx8 PC4-2133P-R Kit
£90.58
saving £8.65
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2133MHz
Brand: HPE
Price Range Ex VAT: 50 - 100
