Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
- HP - DDR3 - 4 GB - DIMM 240-pin - unbuffered
- Product Type
- RAM memory
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1866 MHz (PC3-14900)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP E2Q91AA
- Designed For
- Workstation Z1 G2, Z420, Z620, Z820
- Capacity
- 4 GB
- Upgrade Type
- System specific
- HP E2Q91AA
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Unbuffered
- Chips Organization
- 256 x 8
- Compatible Slots
- 1 x memory
- Designed For
- HP Workstation Z1 G2, Z420, Z620, Z820
