Your basket is empty
HPE HP 3TB SAS 7200rpm 3.5" DP MDL HDD
Quicklinx: 7R78WS00 Mfr#: 625031-B21
Type: Hard drive
Controller Type: None
£533.64 ex VAT
£640.36 inc VAT
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Dual Port Midline - hard drive - 3 TB - SAS 6Gb/s
Hard drive - hot-swap
3 TB
3.5" LFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
11.1 cm x 18.9 cm x 2.6 cm
1 year warranty
Modular Disk System 600; ProLiant DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL165 G7 Base (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL320 G6 (3.5"), DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL370 G6 Special Server (3.5"), DL380 G7 (3.5"), ML150 G6; StorageWorks Disk Enclosure D2600; StorageWorks Modular Disk System 600, 600 with two Dual Port I/O Module System; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2; StoreAll 9730 Storage Couplet; StoreEasy 12 LFF Disk Enclosure
3 TB
3.5" LFF
SAS 6Gb/s
11.1 cm
18.9 cm
2.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.1 ms (average) / 15.5 ms (max)
Track-to-Track Seek Time
0.5 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
2 x SAS 6Gb/s
Compatible Bay
3.5" LFF
Limited warranty - 1 year
10 °C
35 °C
HPE Modular Disk System 600 , HPE ProLiant DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL165 G7 Base (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL320 G6 (3.5"), DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL370 G6 Special Server (3.5"), DL380 G7 (3.5"), ML150 G6 , HPE StorageWorks Disk Enclosure D2600 , HPE StorageWorks Modular Disk System 600, 600 with two Dual Port I/O Module System , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2 , HPE StoreAll 9730 Storage Couplet , HPE StoreEasy 12 LFF Disk Enclosure
Type: Hard drive
Brand: HPE
Price Range Ex VAT: 500 - 750
