Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
Designed and Engineered to Provide Reliable and Cost Efficient Data Storage
The HPE Server SATA Hard Drives increase reliability and lower start-up costs without sacrificing reliability with non-mission critical hard drives at the lowest $/GB.Both cost and capacity optimized solutions provide up to 10 TB of storage in a single device. Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) that are available in a wide variety of capacity points.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.6 Gb/sec data transfer rate supporting existing servers.
- HPE Midline - hard drive - 3 TB - SATA 3Gb/s
- Hard drive - hot-swap
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
- 11.1 cm x 18.4 cm x 2.6 cm
- 1-year warranty
- Designed For
- Modular Disk System 600; ProLiant DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL165 G7 Base (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL185 G5, DL185 G5 Special Server, DL320 G6 (3.5"), DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL380 G7 (3.5"), ML150 G6; StorageWorks Disk Enclosure D2600; StorageWorks Modular Disk System 600, 600 with two Dual Port I/O Module System; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2 (3.5" LFF)
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 3Gb/s
- Bytes per Sector
- 512
- 11.1 cm
- 18.4 cm
- 2.6 cm
Performance
- Drive Transfer Rate
- 300 MBps (external)
- Seek Time
- 8.1 ms (average) / 15.5 ms (max)
- Track-to-Track Seek Time
- 0.5 ms
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 3 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - 1 year
- 10 °C
- 35 °C
- Designed For
- HPE Modular Disk System 600 , HPE ProLiant DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL165 G7 Base (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL185 G5, DL185 G5 Special Server, DL320 G6 (3.5"), DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL380 G7 (3.5"), ML150 G6 , HPE StorageWorks Disk Enclosure D2600 , HPE StorageWorks Modular Disk System 600, 600 with two Dual Port I/O Module System , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2 (3.5" LFF)
