Product
HPE HP 361T PCIe Dual Port Gigabit NIC
Quicklinx: BFCWWS00 Mfr#: C3N37AA
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
£116.84 ex VAT
£140.20 inc VAT
The HP 361T PCIe Dual Port Gigabit NIC is a high performance PCI Express (PCIe) Gen 2.1 dual port, copper, gigabit network solution for HP Z-Workstation customers who demand the latest in dual port Gigabit Ethernet bandwidth and features.
HP 361T - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.1 x4
PCI Specification Revision
PCIe 2.1
Ports
Gigabit Ethernet x 2
13.5 cm x 6.4 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1 x I350 - Intel
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
Red Hat Enterprise Linux 4, SUSE Linux Enterprise Desktop 11, SUSE Linux Enterprise Desktop 10, Red Hat Enterprise Linux 5, Microsoft Windows 7 Professional (32/64 bits), Red Hat Enterprise Linux 6
Workstation Z220, Z420, Z620, Z820
Network adapter
PCI Express 2.1 x4
PCIe 2.1
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP
Status Indicators
Port transmission speed, link/activity
Auto-negotiation, wake on LAN (WOL), network fault tolerance (NFT), Jumbo Frames support, PXE support, Large Send Offload (LSO), Energy Efficient Ethernet
Processor / Memory
1 x I350 - Intel
2 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express 2.1 x4 - low-profile
Low-profile bracket
FCC Class B certified, DOC-B, EN 60950, UL 1950, VCCI-II, EN55024, UL 60950, WHQL, EN55022 Class B, RoHS, ACPI 1.1a
13.5 cm
6.4 cm
55 °C
10 - 95% (non-condensing)
HP Workstation Z220, Z420, Z620, Z820
BFCW C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
BFCW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
BFCW C2G 2m Cat6a Shielded Patch - Blue In Stock £7.02
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: HPE
Price Range Ex VAT: 100 - 150
