HPE HP 3600-48-PoE+ v2 EI 48 Port Managed Rack-Mountable Switch
Quicklinx: 980ZWS00 Mfr#: JG302B
Type: Fast Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£2,097.98 ex VAT
£2,517.57 inc VAT
The HP 3600 EI Switch Series delivers resiliency, security, and reliability at the enterprise edge with support for advanced Layer 3 and multicast routing. This advanced Layer 3 Fast Ethernet switch series has a robust feature set supporting IRF stacking, Static & RIP Routing, OSPF, BGP, IS-IS, PoE+, ACLs, and IPv6. The HP 3600 EI Switch Series can be managed with the optional HP Intelligent Management Center (IMC) Software Platform for a single view of your entire network and includes a Limited Lifetime Warranty 2.0 with 3 years 24x7 phone support.
  • Resilient and Reliable Fast Ethernet Access Layer Switches
    The HPE 3600 EI Switch Series delivers resiliency, security, and reliability at the enterprise edge with support for advanced Layer 3 and multicast routing.Designed for increased flexibility and scalability, the 3600 EI Switch Series comes with 24- or 48-10/100 ports and 4 SFP Gigabit Ethernet ports for stacking and uplinks, a 24-port 100BASE-FX switch with 2 or 4 Gigabit Ethernet SFP slots and models with 370 W of PoE+ power.Hewlett Packard Enterprise Intelligent Resilient Fabric (IRF) virtualizes up to nine physical switches into one logical device for simpler, flatter, more agile networks.Enterprise class features include Dynamic and Multicast Routing, RIP, OSPF, BGP, PIM, and ECMP.Limited Lifetime Warranty and no software licensing required.
  • Powerful Quality of Service (QoS)
    The HPE 3600 EI Switch Series supports advanced, classifier-based QoS which directs traffic using multiple match criteria based on Layer 2, 3, and 4 information and applies QoS policies such as setting priority level and rate limit to selected traffic on a per-port or per-VLAN basis.Provides extensive traffic prioritization with congestion actions: strict priority (SP), weighted round robin (WRR), weighted fair queuing (WFQ), and weighted random early discard (WRED).
  • Integrated and Distributed Security Enforcement
    The HPE 3600 EI Switch Series supports flexible authentication methods including 802.1X, MAC, and Web for greater, policy-driven application security.Identity-driven security and access control with automatic VLAN assignment and per-user ACLs allows access to specific network services without risking network security.Security features include: IP source guard, STP BPDU port protection, and RADIUS/HWTACACS.
  • Single View of the Network
    The HPE 3600 EI Switch Series can be seamlessly managed with the optional HPE Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events.
HPE 3600-48-PoE+ v2 EI - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE+) + 4 x Gigabit SFP + 2 x shared 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
320 W
Performance
Throughput: 13.1 Mpps , Routing/switching capacity: 17.6 Gbps
IPv4 routing table entries: 12000
MAC Address Table Size
32000 entries
Jumbo Frame Support
9216 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, MSDP, static IPv4 routing, static IPv6 routing, ECMP, RIPng, BGP-4+
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IPv6 support, half duplex mode, full duplex mode, sFlow, STP support, RSTP support, VRRP support, MSTP support, TFTP support, ACL support, QoS, CAR, Jumbo Frames support, MLD snooping, DLDP support, RRPP, BFD, EAD, STP Root Guard, IPv4 support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at
44 cm x 42 cm x 4.36 cm
10 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
320 W
Performance
32000 entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2), HWTACACS
RAM
256 MB SDRAM
Flash Memory
128 MB
48 x 100Base-TX RJ-45 PoE+ , 4 x Gigabit LAN SFP , 2 x 1000Base-T RJ-45 , 1 x serial (console) RJ-45 management
Internal power supply
440 Watt
Rack Mounting Kit
Included
CISPR 22 Class A, EN 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EMC, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, CSA C22.2 No. 60950-1, EN 60825-1, ANSI C63.4-2003, EN 60825-2, EN 300 386
44 cm
42 cm
4.36 cm
10 kg
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
980Z C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
980Z C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.96
980Z C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.76
980Z HPE X120 1G SFP LC LX Transceiver In Stock £355.96
980Z HPE Premier Flex LC/LC OM4 2f 1m Cbl In Stock £49.29
980Z HPE Premier Flex Network cable 5m Fibre Optic In Stock £36.22
Type: Fast Ethernet
Ports: 48
Managed: Yes
POE: PoE+
Brand: HPE
Price Range Ex VAT: £1500+
