Your basket is empty
HPE HP 300GB 12G 15K 3.5in SCC Enterprise Hard Drive
Quicklinx: B2K5WS00 Mfr#: 737261-B21
Form Factor: 3.5" LFF
Type: Hard drive
Capacity: 300GB
Spin Speed (rpm): 15000rpm
Stock Status: Clearance
Hurry, only 2 left in stock!
£262.14 ex VAT
£314.56 inc VAT
Express delivery Delivered on Tuesday
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE - hard drive - 300 GB - SAS 12Gb/s
Hard drive - hot-swap
300 GB
3.5" LFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
15000 rpm
105.8 mm x 170 mm x 26.8 mm
1.36 kg
3 years warranty
Bundled with
HP SmartDrive carrier
ProLiant DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL80 Gen9, ML110 Gen9, ML30 Gen9, ML310e Gen8, ML350e Gen8, ML350p Gen8
300 GB
3.5" LFF
SAS 12Gb/s
Bytes per Sector
512
105.8 mm
170 mm
26.8 mm
1.36 kg
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
2.9 ms (average) / 5.9 ms (max)
Track-to-Track Seek Time
0.15 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
3.5" LFF
WEEE
Limited warranty - 3 years
10 °C
35 °C
HPE ProLiant DL160 Gen8 (3.5"), DL160 Gen8 Base (3.5"), DL160 Gen8 Entry (3.5"), DL160 Gen8 Performance (3.5"), DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 Special Server (3.5"), DL320e Gen8 v2 (3.5"), DL320e Gen8 v2 Base (3.5"), DL320e Gen8 v2 Performance (3.5"), DL360 Gen9 CMS (3.5"), DL360 Gen9 Entry (3.5"), DL360e Gen8 (3.5"), DL360e Gen8 Base (3.5"), DL360e Gen8 Entry (3.5"), DL360e Gen8 Performance (3.5"), DL360e Gen8 Special Server (3.5"), DL360p Gen8 Special Server (3.5"), DL380 Gen9 (3.5"), DL380 Gen9 Base (3.5"), DL380 Gen9 Entry (3.5"), DL380 Gen9 Performance (3.5"), DL380e Gen8 (3.5"), DL380e Gen8 Base (3.5"), DL380e Gen8 Entry (3.5"), DL380e Gen8 High Performance (3.5"), DL380e Gen8 Storage (3.5"), DL380p Gen8 (3.5"), DL380p Gen8 Base (3.5"), DL380p Gen8 Entry (3.5"), DL380p Gen8 High Performance (3.5"), DL380p Gen8 Performance (3.5"), DL380p Gen8 Special (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML110 Gen9 (3.5"), ML110 Gen9 Base (3.5"), ML110 Gen9 Entry (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5"), ML310e Gen8 (3.5"), ML310e Gen8 Base (3.5"), ML310e Gen8 Entry (3.5"), ML310e Gen8 Performance (3.5"), ML310e Gen8 v2 (3.5"), ML310e Gen8 v2 Base (3.5"), ML310e Gen8 v2 Enty (3.5"), ML310e Gen8 v2 Performance (3.5"), ML350e Gen8 (3.5"), ML350e Gen8 Base (3.5"), ML350e Gen8 Entry (3.5"), ML350e Gen8 Performance (3.5"), ML350e Gen8 v2 (3.5"), ML350e Gen8 v2 Base (3.5"), ML350e Gen8 v2 Entry (3.5"), ML350p Gen8 (3.5"), ML350p Gen8 Base (3.5"), ML350p Gen8 Entry (3.5"), ML350p Gen8 Performance (3.5"), ML350p Gen8 Special Server (3.5")
HPE HP 300GB 12G 15K 3.5in SCC Enterprise Hard Drive Bundle deal on HPE HP 300GB 12G 15K 3.5in SCC Enterprise Hard Drive
£278.46
saving £7.64
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: B2K5 035079
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £238.76
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Hard drive
Capacity: 300GB
Brand: HPE
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
