Your basket is empty
HPE HP 2GB (1x2GB) DDR3-1866 MHz ECC RAM
Quicklinx: BFBYWS00 Mfr#: E2Q90AA
Type: DDR3 SDRAM
Capacity: 2GB
Connection: DIMM 240-pin
Speed: 1866MHz
Registered/Buffered: Unbuffered
£36.54 ex VAT
£43.84 inc VAT
Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
HPE - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz ( PC3-14900 )
Unbuffered
1 year warranty
Workstation Z1 G2, Z420, Z620, Z820
2 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
1 year warranty
HP Workstation Z1 G2, Z420, Z620, Z820
Type: DDR3 SDRAM
Capacity: 2GB
Speed: 1866MHz
Brand: HPE
Price Range Ex VAT: 0 - 50
